Help me choosing a monitor.
Nightblu33
5 (0.00/day)
I just upgraded my pc and i want to buy a new monitor and i can`t decide between these 2 monitors:
LG 32GK650F-B and LG GL850-B
I would go for the 32" LG for the bigger screen but i don`t like that it has a VA panel and almost all VA monitors i had , had ghosting issues but i`ve seen some very good review at it.
Which one should i get?
6,426 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Neither, buy M32Q on promo.
6,426 (2.85/day)
Poland
Then GL 850.
175 (0.07/day)
System Name Carbon-14900K
Processor Intel i9-14900K
Motherboard MSI Z790 Carbon Wifi
Cooling Arctic Liquid Freezer III 360mm AIO
Memory G-Skill Trident Z5 4 x 16GB DDR5 6800
Video Card(s) Palit Game Rock RTX 4090
Storage Western digital Black SN850X 1&2TB - PCIe Gen 4 M.2-2 Western Digital Blue 1TB SN750 PCIe Gen 3
Display(s) MSI Optix MPG341CQR Ulta-wide 3440x1440p 144Hz and a Samsung 50 inch TV 4K TV
Case NZXT H7 Flow
Audio Device(s) Creative Sound Blaster X4
Power Supply NZXT C1200w Gold
Mouse Corsair M65 Pro Mouse
Keyboard Corsair STRAFE MK2 RGB
Benchmark Scores Cinebench R23 = 41070 Multicore test
I would go for 32Inch as the size will make a difference. I have used IPS and now I am using a VA in the 34inch MSI Optix MPG341CQR which is a VA panel and though dark level smearing has been mentioned, the contrast ratio on VA panels does make a big difference. I play a lot of Racing Simulation games in Assetto Corsa Comp, AMS2, R3R etc and the games look fantastic and to be honest smearing is not an issue..
Both monitors you have mentioned have been reviewed vey well by Hardware unboxed so you can't really go wrong..
Nightblu33
5 (0.00/day)
I don`t know if is worth to sacrifice the better response times , ips panel, better pixel density, better colors for the bigger size.
I mean the lg gk650 has better contrast and deeper black but that`s pretty all advantages.
3,105 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
look for the new GP850 (since it replaces the GL it can be found cheaper and it's a faster and better monitor)
6,426 (2.85/day)
Poland
x2
GP is from the current lineup, would be helpful to know location of OP.
849 (0.12/day)
Terminus GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) RX 9070 XT Hellstone OC
Case Rocketfish (Lian Li) e-ATX (2006)
Audio Device(s) Harman Kardon HK695 2.1
Mouse HP HDX wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
Another feature for the GL850 is that it has HDR10. However, some reviews say the HDR support is just mediocre. The GK650 doesn't have HDR support, but the plus side to that is it can't provide bad HDR. :laugh:
I have the 32GK650. I use it for racing sims and MS Flight Simulator and it looks great in those applications. I'm not using it for FPS or RPG gaming.
Nightblu33
5 (0.00/day)
HDR is useless
562 (0.27/day)
Processor i9-9900K @ 5.1GHz (H2O Cooled)
Motherboard Gigabyte Z390 Aorus Master
Cooling CPU = EK Velocity / GPU = EK Vector
Memory 32GB - G-Skill Trident Z RGB @ 3200MHz
Video Card(s) AMD RX 6900 XT (H2O Cooled)
Storage Samsung 860 EVO - 970 EVO - 870 QVO
Display(s) Samsung QN90A 50" 4K TV & LG 20" 1600x900
Case Lian Li O11-D
Audio Device(s) Presonus Studio 192
Power Supply Seasonic Prime Ultra Titanium 850W
Mouse Logitech MX Anywhere 2S
Keyboard Matias RGB Backlit Keyboard
Software Windows 10 & macOS (Hackintosh)
HDR is useless
are you saying HDR on this alleged poor HDR implementation monitor is useless?
True poor HDR is not something anyone wants to look at. you would pay for a feature you would never want to use
or are you saying HDR in general is useless?
this would be completely false. good HDR is superior to SDR in every way possible
Nightblu33
5 (0.00/day)
Not in general , i mean all HDR monitors below 600 nits are useless.
