- Feb 24, 2021
- 19 (0.01/day)
- Denmark
Processor | Core i7 8700K |
Motherboard | Asus Strix Z370-E |
Cooling | Corsair Hydro H115i Pro |
Memory | 2x8 G.Skill 3600 MHz 16-16-16-36 |
Video Card(s) | Asus Radeon RX 6800 |
Storage | 1 TB Samsung Evo 970 Nvme |
Display(s) | LG UC88 34" |
Case | Fractal Design R6 |
Power Supply | Corsair TX850 |
So, I have for a week tried to hit a stable 5,0 GHz OC on my 8700K with Asus Strix-E Z370. I withdrew to 4,9. I've had long, stable runs at 1.31 VCore (Manual) on this clock.
Then suddenly a freeze on Desktop in an idle moment, like opening a browser or typing something in a document after HOURS of torturous work in benchmarks and games.
I am baffled.
Temps are low. During IntelBurn cores sometimes peak at 83°C but generally ranges from 65 to 75. During gaming way less.
I gave up on adaptive and run with Manual Vcore of 1,31
I have set LLC to 5
XMP is set, to 3600-16-16-16 36. This affects various voltages of the DRAM like VCCIO and System Agent I think. The Dram gets 1,354V
CPU SVID Support is Disabled
SVID behaviour is set to Typical Scenario (but not sure how much it matters since I disabled SVID?).
C states etc. are enabled.
I disabled Asus Core Enhancements.
All core synch to 49
AVX negative offset 1.
Cpu core/cache current limit max. to 255.5
Ring down Auto
Min max cpu cache ratio Auto
So, do I add another 0,01V and see what happens at 1,32? Sounds high for a 4900 GHz OC doesnt it?
I am baffled.
I have set LLC to 5
Ring down Auto
