Help memory with Ryzen 5 1600
105 (0.04/day)
So, i went a little overboard with my new PC build and bought an Acer Predator XB271HU Monitor and a GTX 1080 , initially was supposed to be a normal 1080p 60hz monitor + GTX 1060 6 GB. So you can imagine i am absolutely out of funds to buy a proper fast ram for my ryzen cpu, so i wondering if i can just slap any DDR4 ram in the sysem and be done with it ?
will it work ? i can buy any DDR4 ram and slap it in the mobo and it'll work fine ? i am used to do that with intel without too many problems, but i heard ryzen is different and is finicky when it comes to ram, so it makes me worry. My mother board is ASRock AB350 Pro4 AMD AM4 Socket Motherboard
not to mention i was unable to find any of the suggested ram from my motherboard support page.
824 (0.26/day)
Riverwood, Skyrim
System Name Storm Wrought | Blackwood (HTPC)
Processor AMD Ryzen 9 5900x @stock | i7 2600k
Motherboard Gigabyte X570 Aorus Pro WIFI m-ITX | Some POS gigabyte board
Cooling Deepcool AK620, BQ shadow wings 3 High Spd, stock 180mm |BQ Shadow rock LP + 4x120mm Noctua redux
Memory G.Skill Ripjaws V 2x32GB 4000MHz | 2x4GB 2000MHz @1866
Video Card(s) Powercolor RX 6800XT Red Dragon | PNY a2000 6GB
Storage SX8200 Pro 1TB, 1TB KC3000, 850EVO 500GB, 2+8TB Seagate, LG Blu-ray | 120GB Sandisk SSD, 4TB WD red
Display(s) Samsung UJ590UDE 32" UHD monitor | LG CS 55" OLED
Case Silverstone TJ08B-E | Custom built wooden case (Aus native timbers)
Audio Device(s) Onboard, Sennheiser HD 599 cans / Logitech z163's | Edifier S2000 MKIII via toslink
Power Supply Corsair HX 750 | Corsair SF 450
Mouse Microsoft Pro Intellimouse| Some logitech one
Keyboard GMMK w/ Zelio V2 62g (78g for spacebar) tactile switches & Glorious black keycaps| Some logitech one
VR HMD HTC Vive
Software Win 10 Edu | Ubuntu 22.04
Benchmark Scores Look in the various benchmark threads
You certainly can if you are willing to let it run at low speeds (2133 or 2400MHz), but there is no guarantee that it will run at the higher speeds that Ryzen likes
105 (0.04/day)
oh believe me i certainly am willing to run it at lower speeds if it runs at all. I sacrificed too much and too many for that GPU + Monitor combo and now i am left with no ram or money to buy ryzen certified ram.
if it runs fine then yes i am willing to run it even if its slower, well as long as its okay and works fine and does the job. i do not need it to run at max speeds, speeds at which ryzen likes, i know i am loosing on performance but i have no other options left currently.
1,843 (0.59/day)
BGD
System Name Minotaur
Processor Intel I9 7940X
Motherboard Asus Strix Rog Gaming E X299
Cooling BeQuiet/ double-Fan
Memory 192Gb of RAM DDR4 2400Mhz
Video Card(s) 1)RX 6900XT BIOSTAR 16Gb***2)MATROX M9120LP
Storage 2 x ssd-Kingston 240Gb A400 + HDD 500Gb+2xSSD Kinston 480Gb+5Tb Seagate+512Gb NVME SGI
Case NZXT H5 Flow
Mouse Asus TUF-GAMING M3
VR HMD Oculus Rift DK2
Software Win 11
Benchmark Scores Fire Strike=23905,Cinebench R15=3167,Cinebench R20=7490.Passmark=30689,Geekbench4=32885
Actually Ryzen did have some issues with high frequency RAM speeds at start,not sure how that stands atm. but I am sure that you will be just fine with some DDR4 at 2400Mhz or 2666Mhz.....
sneekypeet
not-so supermod
29,711 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
If you are worried about issues, check the memory QVL before you buy. The motherboard product page should have proven kits of all speeds listed which have been tested to ensure compatibility is not an issue.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
You can use any ram in there, but the more ranks of ram you install, the slower the max speed.
I've got 2x2667Mhz ram (8GB sticks) but being rual rank ram i've had to over-volt a few things in the BIOS to get it stable. Running four of these sticks, i'd probably have to drop the speed.
If you're buying new, try and get single rank ram - many modules are advertised specifically for ryzen, so just get them.
105 (0.04/day)
I am thinking of buying a 1 x 16 GB so i can upgrade in future (maybe in a few months) with an another 1 x 16 GB to a total of 32 Gigs, since i will be using this platform for a long time. But i cannot really afford a fast ram cause i am really out of money for now.
The reason i need that kinda ram is cause its not just gaming that i do on my PC, i also work on it, Database, VM's, VS 2017, Photoshop, Illustrator all while having a ton of chrome tabs open.
44,288 (6.80/day)
If you run high speeds, go with single side ram. Ensure your motherboard gets the latest Agesa update too
105 (0.04/day)
Well, these are my choices
are they any good ? and yes all of them are 1x16 GB than 2x8 GB cause i do plan to upgrade in a few months.
Also seeing how they do not come in sets/pair, can i still run them in dual channel ? like buy these ram 2x and just plug it in ? it worked with intel atleast, but am not sure with ryzen.
