HELP: (Netbook) can't save Power Management settings in Win XP SP3
40 (0.01/day)
Hi!
Well... the problem is as follows: I own a netbook "Nobi Clamshell 10.1" running the above OS. I created an energy profile so the screen will turn off past 5 minutes of inactivity.
The profile works correctly in every session, even if I reboot or turn off the computer.
Today, I tried to modify its "Advanced Options" so when I close the lid of the netbook, the machine doesn't go in stand-by mode. That's where the problem starts.
Every time I reboot or shut-down the computer, that specific setting in Power Management options goes back to default, which is, Go into stand-by if the lid is closed.
I've been trying with several ways to modify it, but everyone results in the same, the setting goes back to default everytime the session is closed.
The same happens with a Win 7 Samsung RV511... this isn't the first time I find this problem.
Does anyone have any ideas how to solve it?
Thanks!!
BTW: Yeah, the user I'm logged in has admin rights, I even tried with the very own Admin account and no luck.
EDIT:
I was able to find the problem by myself... If someone has the same problem (And since this is internet, someone will), the issue comes from an uncompatibility between the third party power manager from the laptop's manufacturer and the one native in windows... In my case, it was Intel Power Manager.
It wasn't enough with disabling it, or even change the name of the directory were it was installed. I had to uninstall it. Then, I was able to got my Advanced Options saved and persisting after closing the session or rebooting.
