help on PC-DVR system. do i need a graphic card?
3,688 (0.58/day)
Ohio
System Name Felix777
Processor Core i5-3570k@stock
Motherboard Biostar H61
Memory 8gb
Video Card(s) XFX RX 470
Storage WD 500GB BLK
Display(s) Acer p236h bd
Case Haf 912
Power Supply Rosewill CAPSTONE 450watt
Software Win 10 x64
Hello all. I just got into building a pc dvr system for my in-laws store. Father in-law bought a Swann DVR8-1450+8camera. He's using 4 camera's and the dvr in his bar. So i built this system from spare parts for his store with the other 4 cameras.
System:
P4 3ghz
2gb ddr400
84gb HDD(upgrading soon)
Mobo with intel 915g express chipset
Using Intel Graphics.
Now i bought a 60fps pci card,however its performance is only decent with one camera and hooking up the 2nd today it looks like its running at 10fps,plus it only records at 320x240 resolution. I believe i got jipped as they state 60fps, but upon looking up the actual chipset i only find 30fps cards matching it.
So here's my main question, last night i purchased another PCI card. Now i'm hoping i made a decent purchase as it states it can record at 30fps per channel, 240fps total on card capable, and recor capable of. Also its stated under requirements that i need a graphics card with 512mb vram. This DVR-PC thing i a whole diff dept to me than building a gaming rig, and i know how game requirements can be overstated/understated. Is this the case here or do i need to buy a graphics card with 512mb of ram? thanks all
3,688 (0.58/day)
Ohio
Memory 8gb
Case Haf 912
Software Win 10 x64
5,048 (0.92/day)
València la Vella
Really no idea, but if you look for the same stuff at, p.e. Amazon, you get user reviews, and that helps!
4,966 (0.85/day)
System Name i7-PC / HTPC / iMac
Processor i7 3820 / Phenom II 940
Motherboard GIGABYTE G1.ASSASSIN2 / M3A79-T Deluxe
Cooling Corsair Hydro H100i / Scythe II (HS only)
Memory G.SKILL Trident X Series 8GB (2 x 4GB) DDR3 1600mhz / 4GB DDR2 1066 (@800) Corsair Dominator
Video Card(s) GB Radeon HD 7950s 3GB / GB Radeon HD 7950s 3GB
Storage 2x 80GB Intel X-25, 2x600gb SATA, 1x1tb 5400RPM storage /1x600GB, 3x500GB,1x160,1x120 SATA
Display(s) 1x 27" Yamakasi / Vizio 42" HDTV
Case Lian Li Lancool PC-K58 / Antec 900
Audio Device(s) HT Omega Striker 7.1 / Onboard and HDMI from ATi Card
Power Supply PC Power & Cooling 750W / 610W
Software Ubuntu / Windows 8.1 Pro / OS X / PHPStorm / Gaming
you shouldn't need a gpu card to record but if you want to display it live you will need the capabilities(RAM) they specify. That also means your first (dvr) card might be better than you thought, and it is probably your integrated graphics that caused the lag. still the new (dvr) card is more suited to your use.
the only way to know for sure without buying a new graphics card, is to record the video and then open the recorded file. It should run smoother, however you may need to view it on a more capable machine to see exactly the quality it records at.
3,427 (0.63/day)
System Name My baby
Processor Athlon II X4 620 @ 3.5GHz, 1.45v, NB @ 2700Mhz, HT @ 2700Mhz - 24hr prime95 stable
Motherboard Asus M4A785TD-V EVO
Cooling Sonic Tower Rev 2 with 120mm Akasa attached, Akasa @ Front, Xilence Red Wing 120mm @ Rear
Memory 8 GB G.Skills 1600Mhz
Video Card(s) ATI ASUS Crossfire 5850
Storage Crucial MX100 SATA 2.5 SSD
Display(s) Lenovo ThinkVision 27" (LEN P27h-10)
Case Antec VSK 2000 Black Tower Case
Audio Device(s) Onkyo TX-SR309 Receiver, 2x Kef Cresta 1, 1x Kef Center 20c
Power Supply OCZ StealthXstream II 600w, 4x12v/18A, 80% efficiency.
Software Windows 10 Professional 64-bit
System:
P4 3ghz
2gb ddr400
I doubt you'll get any good answers here, setting up surveillance equipment is a specialist area which I doubt people here have done.
669 (0.13/day)
mississauga, on, Canada
System Name YACS amd
Processor 5800x,
Motherboard gigabyte x570 aorus gaming elite.
Cooling bykski GPU, and CPU, syscooling p93x pump
Memory corsair vengeance pro rgb, 3600 ddr4 stock timings.
Video Card(s) xfx merc 310 7900xtx
Storage kingston kc3000 2TB, amongst others. Fanxiang s770 2TB
Display(s) benq ew3270u, or acer XB270hu, acer XB280hk, asus VG 278H,
Case lian li LANCOOL III
Audio Device(s) obs,
Power Supply FSP Hydro Ti pro 1000w
Mouse logitech g703
Keyboard durogod keyboard. (cherry brown switches)
Software win 11, win10pro.
i would suggest a gt630v2 ( the one with the 64bit bus) it idles at a very low power level (IMO a record! 4-5 watts i estimated for total peer comsumption of my system)) and if you get the zotac zone version, it is silent... runs a bit hot, but if you are using for video purposes will not matter.
it is sold out on newegg.ca, (i bought one before it was sold out) at 60 dollars it is a great alround card for PVR's (i use mine in a Mythbuntu mythtv setup)
BTW, you should really be using the WD AV-GP drives, as they were designed for Surveillance/PVR Applications
4,357 (0.87/day)
Mexico
System Name Dell-y Driver
Processor Core i5-10400
Motherboard Asrock H410M-HVS
Cooling Intel 95w stock cooler
Memory 2x8 A-DATA 2999Mhz DDR4
Video Card(s) UHD 630
Storage 1TB WD Green M.2 - 4TB Seagate Barracuda
Display(s) Asus PA248 1920x1200 IPS
Case Dell Vostro 270S case
Power Supply Dell 220w
Software Windows 10 64bit
The TW6805 is a 30fps chip: http://catalogs.infocommiq.com/AVCat/images/documents/pdfs/TW6805 Brochure.pdf
Nextchip isn't very informative (http://www.lofty.com.tw/data/nextchip/nvp1104.pdf) as it doesn't state FPS but since there are two chips in the card and each one handles 4 inputs I'd say it would at least be a 60fps card. In the worst case scenario you can hook up two cards to each chip and get 15fps.
OP, you can get 1GB cards for very cheap. Better safe than sorry I say although I'm running 20 cameras with the HD3200 IGP and 512MB. My cards have Techwell chipsets though.
As for the drives, I've been using a WD Blue for about 5 years without issue. Not to say that you should too, just that hardware requirements are often overshoot.
753 (0.17/day)
System Name Chaos
Processor Intel Core i5 4590K @ 4.0 GHz
Motherboard MSI Z97 MPower MAX AC
Cooling Arctic Cooling Freezer i30 + MX4
Memory 4x4 GB Kingston HyperX Beast 2400 GT/s CL11
Video Card(s) Palit GTX 1070 Dual @ stock
Storage 256GB Samsung 840 Pro SSD + 1 TB WD Green (Idle timer off) + 320 GB WD Blue
Display(s) Dell U2515H
Case Fractal Design Define R3
Power Supply Corsair HX750 Platinum
Mouse CM Storm Recon
Keyboard CM Storm Quickfire Pro (MX Red)
Regarding your first card (SV-6805), it doesn't actually encode anything, everything is done on the CPU. The card itself outputs RAW video, which is then converted to MPEG2 or H264 via software/CPU. This could be the reason for low framerate.
The reason the second card is stated to require hefty amounts of VRAM probably lies with it's video encoder chips. I can't know which ones it uses, because they're under heatsinks, but most likely they output video to overlay, or perhaps even to a 2D surface. Both cases require the GPU to render the video stream, rather than just pass it through to the window/screen, and this can be memory-intensive when there are 8 concurrent streams.
512MB is a bit too much to ask, but the 8MB that your 915G can utilize will not suffice.
You'll be fine with one of those "hyper memory" cards, HD5450/6450 for instance, which "borrow" system RAM for use as Vbuffer. Be sure to bump up your RAM accordingly if you go that route, though.
3,688 (0.58/day)
Ohio
Memory 8gb
Case Haf 912
Software Win 10 x64
Thanks for the reply's everyone. Yea I plan to purchase a simple pci-e card from tpu FS forum.
As for the harddrive I had no idea certain hdd were made for surveillance alone. Right now the store's recordings will be removed each week. We live in a small small town so not a huge security hazard but a few things have gone missing that pushed to get them. I was looking at getting an hd 4850, would I be better off getting a higher memory less horsepower and wattage card?
4,357 (0.87/day)
Mexico
I don't think horsepower matters, as I've said, I use the HD3200 IGP. The DVR software uses overlays (DirectDraw) which hardly task GPUs. In my previous configuration I was using a Geforce 6200 512MB with a P4 2.4C.
3,688 (0.58/day)
Ohio
Memory 8gb
Case Haf 912
Software Win 10 x64
Thanks again. I posted a wtb thread and I'm sure ill get some offers. Sad story, I posted this same thread on cctvforums, which is all about security surveillance and dvrs with 200-350 active daily users and still I get my answers from here. Gotta love TPU!
