- Dec 30, 2010
- 1,221 (0.23/day)
- Canada
System Name | Brutus |
Processor | i5 4690k @4.7Ghz (Watercooled) |
Motherboard | z97 MSI Gaming 5 |
Cooling | NZXT Kraken x61 AIO watercooler |
Memory | Gskill Ripjaws 8gb (2x4gb) 1600mhz 7-8-7-24 |
Video Card(s) | MSI Gaming GTX 980ti x2 (sli) |
Storage | 1 SSD 64GB (OS) + 2x500GB WesternDigital RAID 0 |
Display(s) | YAMAKASI Catleap q270 SE 27inch Glossy 2560x1440 |
Case | NZXT Phantom |
Audio Device(s) | ASUS Xonar DX |
Power Supply | Antec TPQ 1200w |
Software | Windows 7 (64 bit) |
For some reason, my computer has started shutting down when left idle for about an hour...
All my power options are configured to avoid this. Hibernation settings are all set to off for every single piece of hardware. no screensavers on... no "automatically shut down computer after updates" for windows update...
No "power savings" plan active... I'm on the the "High performance power plan" which has the same settings this computer always had.
I'm trying to figure out what I might have done recently that might have caused my computer to start shutting down when idling... I installed Team Speak recently... althought I don't know how TS could affect shutdowns...
When I look at my even viewer... There are no critical errors or errors that match the time that the PC shut down.
But there is (in the information logs) an event that matches the time the PC shut down last night.
It says "The kernel power manager has initiated a shutdown transition."
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 109
Version 0
Level 4
Task 103
Opcode 0
Keywords 0x8000000000000004
- TimeCreated
[ SystemTime] 2014-06-07T05:28:57.866455700Z
EventRecordID 336147
Correlation
- Execution
[ ProcessID] 524
[ ThreadID] 528
Channel System
Computer Jonathan-PC
Security
- EventData
ShutdownActionType 4
ShutdownEventCode 0
ShutdownReason 0
So yeah, any help in finding what is causing this would be GREATLY appreciated... as I often leave my computer to run some background programs at night (like utorrent) and don't like coming back to a shutdown computer rather than a computer that has finished its task
- System
- Provider
EventID 109
Version 0
Level 4
Task 103
Opcode 0
- TimeCreated
Correlation
- Execution
[ ProcessID] 524
[ ThreadID] 528
Channel System
Security
- EventData
ShutdownEventCode 0
ShutdownReason 0
