Greetings!
I really hope you can help me. I was just browsing the internet and all the sudden my PC froze. I restarted my PC and after the booting phase I received a windows "bad system config" error that my PC ran into a problem and needed restart. After the first restart I received the same error. I turned off my PC and after boot it began the troubleshooting stage. I managed to use an old copy of my system through the system restore feature and I was finally at desktop. I turned off my pc and I wanted to boot up again to see if everything was fine but at that point the POST problems began.
I turned on my PC, I heard the POST beep with no display and after some seconds the system restarted. My system was now on this restart loop.
I began to troubleshoot by disconnecting and connecting the components and the peripherals one by one.
So now I left connected only the PSU, CPU, MOBO and 1 stick of RAM. With these components connected this is how the system behaves after I turn in on: first restart, one beep noise, no display, second restart, one beep noise, no display, third restart, one beep noise, now I have display for a short duration and all I can see is UEFI Gygabite and after this the system takes it again from the beginning with a restart.
I tried to turn on my PC without the ram stick and only with the PSU and CPU connected to the motherboard. After I turn it on with this config, the pc makes several rapid short beeps.
If anyone can help, it would be greatly appreciated!
Thanks in advance!
Thanks in advance!
