- Apr 26, 2019
- 315 (0.14/day)
- Italy
System Name | The Worker/ Laptop |
Processor | Ryzen 5 3600/ i5 1035g1 |
Motherboard | MSI b450 Tomahawk Max / Lenovo proprietary |
Cooling | Arctic Freezer 33 eSport One |
Memory | 16Gb DDR4 3200 Mhz Corsair vengeance LPX / 12gb ddr4 3200Mhz (4gb are soldered :( ) |
Video Card(s) | Gigabyte gtx 1660 Ti OC @2030Mhz core and 7400Mhz memory / Intel G1 UHD |
Storage | 1 970Evo plus 500gb, 2x250Gb Samsung 850 Evo,3 TB HDD / 250gb WD SN530 |
Display(s) | Asus mx259h / 15.6 FHD TN |
Audio Device(s) | Onboard / Onboard |
Power Supply | CoolerMaster G750M |
Software | W10 64bit |
Hi all.
I have a bit of a mess in my case for cooling so I need your help.
I have the Corsair spec alpha case. It’s not the best but when I purchased it I liked.
It comes with three fans out of the box: 2 on the front with led and one in the back as exhaust.
the 2 on the front are regulated with a switch that lets me select 3 speed levels.
the exhaust one has a 3 pin connector and it’s connected to the motherboard
then I added another Corsair sp120 high performance for better cooling.
now the problem is with this one. I regulated the rpms in the bios to be quiet when idling and When reaching 70C on the cpu it’s set to 100% and the rpms are regulated by its temperature .
the thing that’s sucks is the continuous spikes that has when doing things such as opening apps (not every single one).
do you have any suggestion?
