help ! revive a bricked gtx 560ti
wali2
19 (0.01/day)
i tried the Grounding Sub Vendor Pin method using tweezer , and it worked at a certain point ,because the gpu was bricked and not posting and not detected by windows or nvflash when i put in secondary pci e slot
i use bootable usb with nvflash ,(because the windows version of nvflash doesnt work at all) ,i tried the following command : nvflash --index=1 -j -4 -5 -6 bios.rom (i create autoexec file containning command line using notepad and copy it in usb )
nvflash sees the 560ti when booting first time ,but stops at message overrinding strap and nothing happens and nvflash shows : -:>-
nvflash doesnt recognize the 560ti after this message for example i type --list ,it shows the first gpu adapter and not the 560ti (he sees the gtx560ti at boot only),
edit : the gtx560ti was bricked by a bad flash
edit :nvflash says unkown eeprom
edit: nvflash sees the 560ti when typing --check
pics http://www.hostingpics.net/viewer.php?id=797211201709261335051.jpg
http://www.hostingpics.net/viewer.php?id=179766201709261308131.jpg
http://www.hostingpics.net/viewer.php?id=861295201709261852241.jpg
thanks every body ; i succeeded by retrieving the tweezer 10 seconds after boot, just before nvflash start popping,just when countdown appears , i precise that i use dos version of nvflash in a usb driver
