thanks for all the replies guys...still not 100 % sure what im going to do..lol
Hopefully its not too late for a reply...
Your free system will FOR SURE support up to a 2.2Ghz Northwood 400Mhz FSB processor.
See here:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-39142
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-39548
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-39548#stan
If whoever bought it had ordered it configured that way it would have been a 6792-45U or 6792-43U. SO FOR SURE (As long as you update the BIOS) it can support that processor.
Beyond that its speculation; you could call Lenovo and ask them for the Maximum processor that - that system can support.
I dug through the BIOS & it has been updated to support ALL Northwood steppings. Here are the Release notes for that:
ftp://ftp.software.ibm.com/pc/pccbbs/netvista_bios/20jt46a.txt
HOWEVER, that doesn't mean its a guarantee that it will support faster than 2.2Ghz but its possible.
SO FOR SURE 2.2Ghz, 400Mhz FSB, 512KB L2 Cache:
http://www.cpu-world.com/CPUs/Penti...2 GHz - RK80532PC049512 (BX80532PC2200D).html
If you plug the S-Spec codes into ebay you can find an affordable version... There are Nine different S-SPecs so i'd keep looking until you find one that's really cheap.
I did a look around, unfortunately your plain "Intel 845" chipset is very limited. The 845 E & G etc opened up a lot more processors but SOME plain "INTEL 845" Chipsets list support up to 2.4 & 2.6Ghz (400FSB) so ??? if you are a gambler you might get lucky although the difference between 2.2 & 2.4/2.6 is pretty small. WHO knows you may be even have support for up to the OEM 2.8Ghz 400Mhz FSB (S-Spec code: SL7EY) or 3.0Ghz 400FSB. If you have a Craiglist in your city you might try putting an add asking for someone with a 2.4Ghz -, 2.5, 2.6, 2.8, - 3.0Ghz with a 400Mhz FSB to see if you can try before you buy kind of arrangement.
Years back i bought a powerleap adapter & turned my limited Dell Dimension 8100 1.4Ghz Willamette with a 423 pin chipset into a 478...and dropped in a 2.8Ghz 400Mhz (SL7EY). The Bios doesn't properly detect it at 2.8Ghz...rather it shows up as a 1.6Ghz, however windows sees it and operates it correctly at 2.8Ghz. So who knows what that motherboard will truly support unless they've tried it. Just make sure you have the latest BIOS. That system still runs great as a media PC, server, TV recorder, and media streamer, and HD file player. (it uses RDRAM 800 vs urs with SDRAM)
One last comment. These types of systems are hardly obsolete. I buy up these systems from Universities & corporations liquidating to make room for upgrades and i clean / them fix anything that's broken and resell or donate them. For 85% of the population they have plenty of features & use. They do internet, movies, even HD movies, operate as Media PC's, play-burn-store music, or act as in home servers, word process, and run business spreadsheets/powerpoint etc...
With a decent enough AGP graphics card available for a few bucks...with performance equivalent to 9800-x800XT they will play older games and ALL those kids games. So they FAR from obsolete! I even find people who have good uses for PIII's and PII's. Smoothwall routers, media file sharers, juke boxes blah blah blah.
EDIT:
I Forgot that i have this ALL-In-One IBM NetVista 6274 which has the same motherboard "Intel 845" - 400Mhz FSB only... It is running a 2.4Ghz 400Mhz FSB Celery processor. I just threw it in to test out, after i got the replacement Goofy IBM heatsink, whether the system booted. It was a few months back & then set the system aside after i loaded xp. (it was a University PC that someone robbed some parts, including CPU & heatsink). It even let me flash the BIOS without fully recognizing the 2.4Ghz Celeron (until after it was Flashed). (I'm keeping it more as a novelty PC as its got the 15" LCD monitor & CD/DVD drive built right into one frame)...
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-41199
As you can see this processor came with even slower processors ... i think the fastest it came from IBM with was a 1.9Ghz...So add that to ur knowledge base. If i find a bargain on another SL7EY or ....i'll give it a try. GOOD LUCK!
