Help with Assassin's creed 3. Lag/stutter
1,221 (0.23/day)
Canada
System Name Brutus
Processor i5 4690k @4.7Ghz (Watercooled)
Motherboard z97 MSI Gaming 5
Cooling NZXT Kraken x61 AIO watercooler
Memory Gskill Ripjaws 8gb (2x4gb) 1600mhz 7-8-7-24
Video Card(s) MSI Gaming GTX 980ti x2 (sli)
Storage 1 SSD 64GB (OS) + 2x500GB WesternDigital RAID 0
Display(s) YAMAKASI Catleap q270 SE 27inch Glossy 2560x1440
Case NZXT Phantom
Audio Device(s) ASUS Xonar DX
Power Supply Antec TPQ 1200w
Software Windows 7 (64 bit)
Hi yall. I have 2x gtx 670 in sli... can't play assassin's creed at all... its crazy
the fps seems to be all over the place... I turned off v-sync... and tried with and without sli... same problem... the fps just jumps all over the place constantly... Any clue what is causing this?
my drivers are up to date. (I'm using evga precsion btw)
OneMoar
There is Always Moar
8,837 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
is "Adaptive vsync" OFF ? check the NVCp
1,221 (0.23/day)
Canada
System Name Brutus
Case NZXT Phantom
No its off. I found the problem... appearantly its the core affinity. God its incredible how pc gaming is more complex than console gaming...
everytime I install a new game I always have to toy around with the following until I get decent performance:
-vsync (off on forced d3d... etc)
- Resolution (refresh rate)
- Hyperthreading, on vs off
- .ini tweaking...
crazy stuff
so just one question: I got a quad core with hyperthreading, which cores are the virtual ones again? ...
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
#1, 3, 5, 7 are the virtual cores.. I'm pretty sure. (I don't think Intel has changed the order) If you're just doing mostly gaming on your computer right now, it may be a good idea to turn hyperthreading off in the bios. :)
I'm wrong 4-7 are virtual cores. :eek:
1,221 (0.23/day)
Canada
System Name Brutus
Case NZXT Phantom
well I did pay 300$+ for this CPU and it's hyper threading features... had I bought a 180$ i5 with no ht I might consider this as an option...
Hyper threading does help in quite a few other things I do on my PC... but yeah, I'll try turning it off to see if it solves the problem.
OneMoar
8,837 (1.61/day)
Rochester area
its not really the cpus fault its just that ac3 is a crappy console port
1,221 (0.23/day)
Canada
System Name Brutus
Case NZXT Phantom
yes, assassin's creed games are so fun to play, but so badly optimized indeed.
It's crazy how in console ports... you look one way and you get a perfect 60 fps, and you look the other way, and BaNG! your fps drops by half. and it isn't because of view distance and LODs... it's all because of poor GPU/CPU optimization (threading ant whatnot...)
1,221 (0.23/day)
Canada
System Name Brutus
Case NZXT Phantom
so I tried turning off HT, and it doesn't completly fix the problem... Surprisingly, when I set the priority to "real time" in task manager... it helps quite a lot... now I'm trying to eleminate my stupid frame drops... when looking @ a dense tree line...
*** How can I get the game to always start with the "real time" priority in task manager" ?? ***
1,400 (0.29/day)
78°55' N, 11°56' E
System Name -aLiEn beaTs-
Processor Intel i7 11700kf @ 5.055Ghz
Motherboard MSI Z490 Unify
Cooling Corsair H115i Pro RGB
Memory G.skill Royal Silver 4400 cl17 @ 4403mhz
Video Card(s) Zotac GTX 980TI AMP!Omega Factory OC 1418MHz
Storage Intel SSD 330, Crucial SSD MX300 & MX500
Display(s) Samsung C24FG73 144HZ
Case CoolerMaster HAF 932 USB3.0
Audio Device(s) X-Fi Titanium HD @ 2.1 Bose acoustimass 5
Power Supply CoolerMaster 850W v2 gold atx 2.52
Mouse Razer viper 8k
Keyboard Logitech G19s
Software Windows 11 Pro 21h2 64Bit
Benchmark Scores ► ♪♫♪♩♬♫♪♭
lower detail from ultra/v.high to high to see if it helps.
1,221 (0.23/day)
Canada
System Name Brutus
Case NZXT Phantom
I lowered everything, and I do gain a 6fps increase avg... but still get unacceptable FPS drops to 32fps (should never happen ... when considering the fact that I have an i7cpu and 2x gtx 670...)
46 (0.01/day)
Bali Indonesia
System Name New Comer...
Processor i7 3770k + fx6300
Motherboard Sabertooth z77 + GA 970 D3
Cooling Noctua NH-D14 + Thermolab Baram
Memory 2x4gb Ripjaws + 2x4gb Vengeance
Video Card(s) HIS 7950 + HIS 7770
Storage M4 ssd + 2x1tb Caviar Blue
Display(s) Samsung BX2450 24"
Case Stryker + Antec 900
Audio Device(s) OnBoard
Power Supply Seasonic p760 + Seasonic M12II-520
Software Windows 7 Ultimate 64
U should get boston fix for that game it will fix the low fps problem...
1,221 (0.23/day)
Canada
System Name Brutus
Case NZXT Phantom
what's the "boston fix" you're talking about?
51 (0.01/day)
Canada
System Name AORUS Elite Ice™
Processor Ryzen 7 9800X3D
Motherboard Gigabyte X870 AORUS ELITE WIFI7 ICE
Cooling Arctic Liquid Freezer III 240 A-RGB White
Memory CORSAIR Vengeance RGB 32GB (2x16GB) DDR5 6000MHz
Video Card(s) GIGABYTE AERO GeForce RTX 4090 24GB
Storage Samsung 990 Pro 2TB/Samsung 980 Pro M.2 1TB /1 x Samsung 970 Evo Plus 1TB/Samsung 850 Pro Series 1TB
Display(s) Samsung S95B / LG 27GR95QE-B 27" 240Hz 1440P / ASUS TUF Gaming VG27AQ 27" 1440P 165hz
Case Lian Li Lancool II Mesh RGB White
Audio Device(s) Creative Sound BlasterX AE-5 Plus Pure Edition W/ Logitech Z-5500 5.1
Power Supply Seasonic FOCUS Plus 850W Gold
Mouse Logitech G502 Hero K/DA
Keyboard Corsair K70 RGB MK.2 SE RAPIDFIRE Cherry MX Speed
Software Windows 11 Pro x64
1,221 (0.23/day)
Canada
System Name Brutus
Case NZXT Phantom
lol... that's a good search link... and there's no "fix" mentionned... just a bunch of speculations about hardware and all...
I wanna know "exactly" what he's talkin about
46 (0.01/day)
Bali Indonesia
It's a patch for ac3 low fps or lag at boston episode after the pirate ship
Boston Fix
1,221 (0.23/day)
Canada
System Name Brutus
Case NZXT Phantom
appearantly gonna take 2 days to download that link... downloading around 4kbs/sec :(
46 (0.01/day)
Bali Indonesia
Yeah that's local link i know sorry
maybe torrent will help u
1,221 (0.23/day)
Canada
System Name Brutus
Case NZXT Phantom
what's the name of the fix? I typed in google "assassin's creed 3 boston fix" ... and I find youtube videos that have nothing to do with your file... and forum threads that are as pointless...
I typed in the name of the file u linked me in google, and I get non-sense results again...
Do you remember "where" you got that file?
46 (0.01/day)
Bali Indonesia
maybe u can search this DataPC DX11 AC3 Boston on torrent
edit i don't found that one either on torrent sorry
but i found these
Boston Fix
1,221 (0.23/day)
Canada
System Name Brutus
Case NZXT Phantom
your link gets "blocked" by my browser
fishy link?
46 (0.01/day)
Bali Indonesia
yesterday when i search it was just fine now it's reported "this site may harm your computer"
well i don't know where to look again now sorry
edit try
Boston Fix
1,079 (0.22/day)
Indonesia
Processor AMD Ryzen 9 7900
Motherboard Gigabyte B650M AORUS PRO AX
Cooling THERMALRIGHT Phantom Spirit 120 EVO
Memory G.SKILL Flare X5 DDR5-6000 64GB (2x32GB)
Video Card(s) Manli RTX 5070 Ti NEBULA
Storage 2 TB WD Black SN850X | 2 TB WD Blue SN570 | 10 TB WD Purple Pro
Display(s) Xiaomi G27Qi 27" 2K QHD IPS 180Hz
Case Fractal Design Define R5 Black
Power Supply SEASONIC FOCUS PLATINUM PX-850 850W
Mouse Fantech Helios II Pro S
Keyboard KIRA EXS
Turn off your power saving features, make sure your CPU always running full speed, that's how I deal with stuttering in this game.
When I play this game with AMD Cool n' Quiet enabled, I got stuttering and choppy gameplay.
I can't find the solution, but one day all those stuttering and choppiness gone.
Checking my system and I found that my WCG BOINC client is running on the background (I forgot to turned it off, and this is meaning that 90% of the time my CPU running at full speed).
So I go to BIOS, turned off Cool n' Quiet and no stuttering and choppy gameplay anymore.
Also try to set your Anti-aliasing and AF from NVIDIA Control Panel, also make sure that your settings override any in-game AA and AF settings.
Oh, assuming that you bought your game legally then that "Boston fix" is not what you think it is, trust me, I know :D
1,221 (0.23/day)
Canada
System Name Brutus
Case NZXT Phantom
yeah, that boston fix sounds like the fishiest of the fishiest things ever lol
