Help with IDE Controller
happy
638 (0.13/day)
System Name HAPPY
Processor i7-2600
Motherboard ASRock P67 EXTREME4 GEN3
Cooling CORSAIR CAFA50 (CPU)
Memory 4GB 1333mhz
Video Card(s) GIGABYTE GV-N460OC-1GI
Storage HITACHI 160GB 7200RPM HDT721016SLA380 & 5 IDE 250GB WD HDD
Power Supply Corsair 650 TX
Hi so I have 3 of the Promise Ultra133 TX2 PCI IDE Controllers and I wanted to use them on my new 1155 mobo. I have inserted it in the mobo and on boot the mobo does recognize it. It recognizes my IDE HDDs. But how to I am I able to view it on the the desktop. I tried to go to device manager and the other thing to allocate the thing like how I did for my other 1tb SATA HDD but no luck. Please help. Sad to see all 9 of my IDE HDDs not going to be able to be used. I also tried to install the drivers winxp because no win7 support but it does not have a setup application. It has like wierd junk that I can't run. :(
2,365 (0.44/day)
Marlow, ENGLAND
System Name Chachamaru-IV | Retro Battlestation
Processor AMD Ryzen 9 5900X | Intel Pentium II 450MHz
Motherboard ASUS ROG STRIX X570-F Gaming | MSI MS-6116 (Intel 440BX chipset)
Cooling Noctua NH-D15 SE-AM4
Memory 32GB Corsair DDR4-3000 (16-20-20-38) | 512MB PC133 SDRAM
Video Card(s) nVIDIA GeForce RTX 4070 FE | 3dfx Voodoo3 3000
Storage 1TB WD_Black SN850 SSD (OS), 3TB Toshiba (Storage), 8TB Seagate FireCuda/2TB WD_Black SN580X (Steam)
Display(s) Samsung Odyssey G5 27" @ 1440p144 & Dell U2412M @ 1200p60
Case SilverStone Seta A1 | Beige box
Audio Device(s) Creative Sound Blaster AE-7, Edifier speakers, Grado Labs SR80 X headphones | Sound Blaster AWE64
Power Supply EVGA Supernova 750 G2 | 250W ASETEC
Mouse MX Master 3S| Microsoft Serial Mouse v2.0A
Keyboard Vortex Race3 | Dell AT102W
Software Microsoft Windows 11 Pro | Microsoft Windows 98SE
507 (0.09/day)
System Name Home Theatre
Processor i5 750
Motherboard Gigabyte P55 USB3
Memory 4GB ADATA 1333
Video Card(s) Sapphire 1GB ATI 5670
Storage 32gb Kingston SSD (Os)/ 1TB and 640GB Caviar Blue (Storage)
Display(s) Sony KDL40HX800
Case Cooler Master HAF 922
Audio Device(s) HT Claro Plus
Power Supply Corsair HX650
Software Windows 7 64-bit
507 (0.09/day)
Processor i5 750
Then install the application
2,365 (0.44/day)
Marlow, ENGLAND
Go into device manager by right-clicking on My Computer and clicking Manage. Then click Device Manager.
You should see some Unknown Devices or some with yellow ?'s or red !'s. Right-click on one, click Update Driver Software. The wizard should guide you through, click "Browse my computer for driver software" then "Let me pick from a list of device drivers on my computer". Click "Have Disk" and browse to the folder you extracted the driver to and select the .inf file. Ignore any errors it might bring up about it not being compatible or digitally signed. It should work.
theonedub
habe fidem
8,026 (1.37/day)
Northern CA, USA
System Name Erakith || AsRock NUCS
Processor AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P
Motherboard MSI X399 MEG Creation || AsRock OE
Cooling EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE
Memory 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4
Video Card(s) Vega 64 EK FC|| Intel Iris Xe
Storage 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro
Display(s) 34" Dell Ultrasharp U3415W
Power Supply Corsair HX1000
Software Windows 10 Pro x64 || WIndows 11 Pro x64
You can try:
Download drivers, extract files, open control panel, open device manager, click on your PC (first icon), open Actions menu, select add legacy hardware, select choose hardware from list, select IDE controller, select have disk, select folder you extracted files to and hope it finds drivers to the device you want to install.
happy
638 (0.13/day)
System Name HAPPY
Processor i7-2600
Memory 4GB 1333mhz
Thanks. imma try to see if it works in a bit.
happy
638 (0.13/day)
System Name HAPPY
Processor i7-2600
Memory 4GB 1333mhz
Should I put all my drives on slave? What if I want to use one of the drive as boot (OS).
2,682 (0.47/day)
System Name Old Gateway
Processor i5 4440 3.1ghz
Motherboard Gateway
Cooling Eh it doesn't thermal throttle
Memory 2x 8GB JEDEC 1600mhz DDR3
Video Card(s) RX 560D 4GB
Storage 240gb 2.5 SSD 3TB 7.2k Seagate
Display(s) Dell @ 1280*1024 75hz
Case Gateway
Audio Device(s) Gateway Diamond Audio EMC2.0-USB 5375U ($15 a long ass time ago)
Power Supply 380w oem
Mouse Purple Walmart special, 1600dpi. Black desk mat
Keyboard SteelSeries Apex 100
VR HMD Lmao
Benchmark Scores It can run Crysis (Original), Doom 2016, and Halo MCC
Just set all the IDE drives to Cable Select. That way you don't have to worry about if they're set in the right mode or not. Also, I'd recommend the Vista driver over the xp driver, the newer one is more likely to be compatible since win7 and vista are similar.
to boot from one you'll need the driver disc that came with the controller cards, are download it onto a disc. if using xp to boot, you'll have to press the key to load 3rd party software when prompted at the bottom. win7 may see it during install, not sure though. still, might want to have the vista drivers on hand for that just in case.
happy
638 (0.13/day)
System Name HAPPY
Processor i7-2600
Memory 4GB 1333mhz
Thanks. I got all four drives to connect and to be recognized. :)
