- Apr 29, 2006
- 5,105 (0.73/day)
- Sydney, Australia
System Name | UltraPC |
Processor | E8500 Core 2 Duo, 1333Mhz FSB, 3.16Ghz @ 4.5GHz (got into Windows @ 4.75GHz) |
Motherboard | ASUS P5Q-e |
Cooling | CPU Cooler - TT V14 Pro, 2x120mm CM Blue LED fans, 1x90mm CM Blue LED fan |
Memory | G.Skill Pi 4GB (2x2GB) Dual Channel DDR2 PC8000 (1000MHz), 5-5-5-15 |
Video Card(s) | Sapphire HD4850 512mb with ASUS EAH4850 BIOS |
Storage | 2x 500GB Seagate 7200.12 Raid 0 |
Display(s) | Acer AL1912, 19" LCD screen |
Case | Thermaltake Soprano Black ATX case |
Audio Device(s) | Onboard 7.1, Speakers - 5 + Sub + Monitor speakers |
Power Supply | Thermaltake 850W Toughpower Cable Management - Quad (2x18A and 2x30A) 12V rails |
Software | Win 7 Pro x64, MSN, CS:Source, etc etc |
Ive currently got Vista loaded on my computer and I plan on installing Fedora 8. So, I used Acronis disk director to resize my main 115GB OS partition to a new partition called linux, being 35GB. I also made this new 35GB partition primary and active.
Just for reference, I have 5 (now 6 with Linux) partitions; C: (with vista on it), Downloads, Games, Family and Programs. This is on a RAID 0 system with 2x250GB HDD's.
Back to the point. I put in the Fedora 8 DVD, did the disk check etc and it was all good. I am now up to the screen where it is asking me to select the media to install linux on. I have four options:
1. Remove all partitions on selected drives and create default layout
2. Remove Linux partitions on selected drives and create default layout
3. Use free space on selected drives and create default layout
4. Create custom layout
All I want Linux (Fedora) to do is use the 35GB active partition I have made and NOTHING more. I have data on other partitions which I can't lose.
When I choose any of the first three options, the only hard drive I can use is the entire 500GB RAID array. I chose the fourth option (custom layout) and pressed next and it took me to a screen where I can actually choose the partitions. If I select the 35GB partition would it just partition that out/install it on there and no affect the other partitions?
Thanks in adv
Thanks in adv
