Help with monitor choice for 3080
Jjrunner
2 (0.00/day)
Hi all
I’ve been spending quite a lot of time researching monitors since I want to upgrade my current Acer Predator 1440 144hz TN panel since I don’t quite like the picture quality anymore. I’ve come to 2 choices that are the Cooler Master GP27Q and the Samsung odyssey NEO G7 as they both use mini led technology with one being 4k and the other 1440p. In Europe with discounts there’s only about 100 dollars difference.
I use the computer for mainly gaming but also some productivity stuff (reading, notes, excel). I mostly play D4, WoW, a bit LoL and then some singleplayer games. The monitor is also gonna be hooked up to a PS5.
I was leaning more towards the Samsung one but I’m just not sure how my 3080 is gonna handle the 4k. I know there’s dlss and I’m okay with not using high/ultra all the time. The earliest I will be upgrading the GPU is in 2 years so it has to handle 4k for that long on an acceptable/good level.
Would any of you guys recommend me a way to go when I’m looking for the best fidelity upgrade?
6,426 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
High frameratr matters, I'd pick GP.
Frick
Fishfaced Nincompoop
20,045 (2.86/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
I'd say this is down to personal preference. 4K on 27" you probably want to scale anyway. If I were you I'd go for the CM, if nothing else because the GPU will not have to work as hard, meaning less noise.
1,683 (2.06/day)
France
System Name KLM
Motherboard B-650E-E Strix
Video Card(s) 4070-ti PNY
Case 4000D Airflow
Power Supply Shift 1000
Mouse 502 Hero
Keyboard K68
VR HMD Steam Deck OLED
Software EMDB
Benchmark Scores 0>1000
825 (0.42/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
I wouldn't recommend Samsung's curved monitors, here in Taiwan we have cases of those monitors delaminating by itself but Samsung blames it on the consumer
There is also 1 case that the consumer had actual camera footage proving that no one had touched it when it delaminated but was still refused warranty
1,683 (2.06/day)
France
System Name KLM
Case 4000D Airflow
Mouse 502 Hero
Keyboard K68
Software EMDB
It's not curve, it's bent !!
Lei
1,143 (0.82/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
For productivity 4k.
framerate doesn't matter unless you play FPS
2,373 (0.56/day)
Audio Device(s) A LOT
For those applications I’d shoot for 4K — you should be able to use them on ultra settings anyway. But I’d try and bump up to 32” at least.
Either way both are fine monitors… You may not notice the advantages of 4K at 27”, depending on how far away you are from your monitor. If you canid go to a retailer and check them out yourself.
3,940 (4.98/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Memory 32 GB DDR4-3200
Storage Yes.
Display(s) MSi G2712
Audio Device(s) Yes.
Software Windows 11 / 10 / 8
27" is a puny size so you can go for 1080p gaming on this monitor if you get into performance issues at 4K and no, 27" is NOT too much for 1080p. Just don't get one feet close as most "humongous pixel size" whiners do.
3080, considering you being ready for loosening graphics settings, will do just fine anyway.
Yet I have ABSOLUTELY no idea how in the world can a curved 16:9 monitor be a thing but it's my eyes who disagree with this concept, not the whole humanity.
I'd go for 4K. With scaling of 200%, software behaves fine. Beware of red flags in the particular makes and you'll be alright.
Jjrunner
2 (0.00/day)
I didn’t know that the Samsung had a 27 inch version but I was looking at the 4k 32 inch model.
I’ll probably order the 4k Samsung - thanks for all the input.
18,450 (2.47/day)
4K any day, from a 4K user since around seven years back. That is if you do any kind of work on your monitor at least. I can't go back to lower resolutions.
I've never had anything bigger than a 27" and find that a comfortable size.
Also, the CM monitors have been having some issues from what I've read, but most of those are meant to have been fixed with firmware updates.
dgianstefani
TPU Proofreader
5,444 (2.04/day)
Swansea, Wales
Benchmark Scores Legendary
4K120 IPS or 1440p 240 Hz fast IPS, or 4K OLED 120 if you can afford it.
1,442 (0.28/day)
Romania
Processor Ryzen 5700x
Motherboard MSI B350 Gaming Pro Carbon
Cooling be quiet dark rock pro 3
Memory GSKill Aegis 32GB (4x8GB) DDR4 3200MHz CL16
Video Card(s) PowerColor Radeon RX 7800 XT Hellhound 16GB GDDR6 256-bit
Storage Seagate Barracuda SATA-II 1TB , HyperX Savage 240GB SATA 3
Display(s) Benq EX2780Q
Case Be Quiet! Dark Base Pro 900
Audio Device(s) Sound BlasterX G6
Power Supply Seasonic prime TX-650
Mouse Marvo Scorpion G981
Keyboard Razer Blackwidow Elite - Yellow Switch
TN panels are dead. IPS or OLED.
RTX 3080 isn't much. 2k 144hz with 27 inch is where you are at. above 27 inch you lose sharpness. 32inch in 2k is too big. That's where 4k hits the spot.
4k gaming has been possible for years. Look at my specs. I game in 4k Forza 5...Mortal Kombat, al sorts of platformers and fighting games. But for AAA, 4k isn't real. Starfield won't be happening at 4k for almost anybody.
A 3080 is basically a 4070. Most serious games will do 2k at 120-150 frames with high very high details. So that's your sweet spot. Be next year 2024, you will have 100-120 frames.
Remember this:
Frames rates are only important above 200 FPS in competitive gaming.
I have been playing COD / Warzone for years at 100 frames, no problem.
What you is need the highest level of detail for eye candy, the most beautiful version of the game's graphics. Something that will look amazing. Anything above 60 frames, while keeping the graphics at ultra etc. is what you want.
Frick
20,045 (2.86/day)
norr
We're all different I suppose. I have a 4K 32" monitor and have to scale anyway, so 1440p would have been a better purchase.
18,450 (2.47/day)
Where do you find these odd 120 Hz monitors? Almost all 4K monitors are 144 Hz or higher, or 60 Hz, never seen any 27 or 32-inch models that are 120 Hz.
I only have 125% scaling and it's perfect.
dgianstefani
TPU Proofreader
5,444 (2.04/day)
Swansea, Wales
Rtings has a good list, it's not complete though.
PCPartPicker too.
I'm meaning these specs as minimums.
69 (0.08/day)
It does not come from the monitor, it is more like a settings recognition, because if you connect a 4K display via HDMI 2.1 you going to get 120Hz/120fps max. Its more like a "console gamers" thing.
True, if you relate it to the topic (3080/PC-Monitor) you would suggest to connect via DisplayPort to get max Hz/fps from the display.
18,450 (2.47/day)
It does not come from the monitor, it is more like a settings recognition, because if you connect via HDMI 2.1 you going to get 120Hz/120fps max. Its more like a "console gamers" thing.
My comment was mostly about the fact that there are very few 120 Hz PC monitors at all, regardless of resolution, as most are either 100 or 144 Hz.
3,940 (4.98/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Storage Yes.
Meanwhile me with a 31.5" FullHD display:
Maybe try social distancing from your monitor. 32" is the diagonal which prefers the end user to be 48", or 4 feet (122 cm) away from a display for ideal experience.
Deleted member 229121
With a 3080 I'd stick with 1440p, 4K you'd want a 4080 / 7900 XTX or 4090 ideally.
4K as said would be ok for less demanding games, but other AAAs would tank at that resolution.
If you're fine with just turning down settings on some things and "growing into" 4K then I get that though (did the same with 1440p myself years ago).
I'm holding out for 4K here but I'm just not in love with any of the more affordable IPS options TBH.
1,442 (0.28/day)
Romania
@Jjrunner it's called PPI ration. That's what I meant by 27" 2k res. So do your own research here. Basically a huge piece of plastic with low PPI will give you horrible clarity/ sharpness. You can't go to high on those inches, or else you lose. And you can't go too high on that resolution, cuz PC won't offer enough frames.
Find a sweet spot.
