You frankly don't need a 850W unit. I've done calculations and a 650W unit would be enough for my system in an overclocked state. I've gone with 750W just to be sure and since I already had that before.
The further you overshoot the need, the worse efficiency you'll have. Ideal is that your usual load falls within 50% usage. Which means you'll have best efficiency when running a bit more intensive stuff and when you're in idle, you'll still be in the good range of 20-25%. If you have too powerful unit, you'll never reach the 50% sweetspot during loads and when in idle, you'll be WAY below the low end sweet spot. Granted, the low end is really difficult these days since CPU's and graphic cards use so little power in idle, but still.
Best way if you're buying for existing system is to measure consumption with watt-o-meter for idle and very high load situations of your existing system.
Now take the watts measured and see where the measured consumption intersects with efficiency line of PSU that you want to buy. Bottom "limit" is usually 20%, the recommended load should be around 50%.
This way you get the best efficiency if you properly allign both consumptions to the highest efficiency you can get from a PSU you're looking at. Overshooting this by a lot by buying a way too powerful PSU means the idle will fall way below 20% sweetspot (which means you'll get poor efficiency when in idle) as well as the 50% which is where PSU's usually reach the highest efficiency.
Graph example:
See how the highest level is at around 50% mark and then starts to fall down? And how the 20% mark is very low and how it would go even lower if your % load of the whole unit is way below that? You can't get away with
Now lets do some calculations...
IDLE: 850W-80%=170W
LOAD: 850W-50%=425W
For 850W unit, this means your system should consume around 170W at idle and 425W when at load to achieve best efficiency. Considering not even my 22nm hexa core has such high consumption at idle, I'd say 850W is a massive overkill for your setup. And same applies for load...
IDLE: 750W-80%=150W
LOAD: 750W-50%=375W
IDLE: 650W-80%=130W
LOAD: 650W-50%=325W
See how sweet spots drop when you take weaker PSU...
When there were very little power saving features in hardware, it was easy. Measure consumption and pick a PSU that has idle and load the closest together at 50%. But today, gaps between idle and load are massive since hardware uses so little power in idle and has huge consumption at load and you have to use 20% and 50% points and decide based on that.
Alternate options are these PSU calculators:
http://www.bequiet.com/en/psucalculator
http://www.corsair.com/en/psu-finder
http://powersupplycalculator.net/
http://outervision.com/power-supply-calculator
Throw in as accurate setup of your system and you'll get a recommended PSU wattage. Be Quiet's calculator even estimates the loads so you can where different wattages fall into what load category. They of course list only their units, but basically if they are same efficiency level, they are comparable with PSU's from other vendors.
