I know the Asus rt n12D1 is out of date but it was highly rated for many years when I bought it and until recently has always done what I needed. However, it has started to fail with more and more frequency. I'm definitely not a networking expert, I can tell you I got the rt n12 to run in repeater mode and I need whatever I get as a replacement to do the same, but it seems a lot of routers say the support something called mesh networking??? Is that just another newer term for repeater? What I need is a new router that can be setup up wirelessly as a repeater to connect to my main (ISP's) wireless router and then have more distant devices connect to repeater instead of the main router. The new repeater should have 4 ethernet ports as well because I have some devices that need to connect to the repeater that way. Any recommendations? I don't need the latest and greatest of anything. With the distance this repeater sits from the main wireless router, I'm probably only going to get a stable 2.4ghz connection between them anyway. I just don't know if these mesh devices will work, or I need to find a router that specifically says it has a repeater mode. I don't have the model number handy but I have whatever Verizon supplied with my fios internet as my main router.
Thanks
Thanks
