- Dec 30, 2010
- 1,221 (0.23/day)
- Canada
System Name | Brutus |
Processor | i5 4690k @4.7Ghz (Watercooled) |
Motherboard | z97 MSI Gaming 5 |
Cooling | NZXT Kraken x61 AIO watercooler |
Memory | Gskill Ripjaws 8gb (2x4gb) 1600mhz 7-8-7-24 |
Video Card(s) | MSI Gaming GTX 980ti x2 (sli) |
Storage | 1 SSD 64GB (OS) + 2x500GB WesternDigital RAID 0 |
Display(s) | YAMAKASI Catleap q270 SE 27inch Glossy 2560x1440 |
Case | NZXT Phantom |
Audio Device(s) | ASUS Xonar DX |
Power Supply | Antec TPQ 1200w |
Software | Windows 7 (64 bit) |
Hey guys, I'm having trouble with my 2 new Rosewill fans...
I got myself 2x 120mm fans to cool my radiator (for my coolit eco alc water cooler...)
And my plan was to control them via some software... But no matter what I do, I can't control the 2nd fan... I can only control the Fan that is plugged into the "CPU_FAN" slot on the motherboard...
In my mobo's manual, it says I can control my fan speeds if the fans are connected into either "CPU_FAN" "CH1_FAN" or "CH2_FAN"...
Obviously, my 2nd fan is connected to the CH1_FAN, yet no matter what I try it's RPMs won't change and I can't control it's speed...
Now I know I could just plug both the fans directly into the powersuppply using the molex... But I'd really like to be able to control my fans manually through software...
I'M TRYING TO avoid having to buy a "Fan controller"... So any of you have experience with this: PLZ HELP ! Thx in advance :O)
