help with translating BSOD error code
connzy
11 (0.00/day)
hey everyone
ive been getting the BSOD recently and its tarting to become a regular occurrence (maybe once every 6 hours) which is starting to become real annoying.
was just wondering if anyone can tell me where to start looking for the problem as im not having much luck googling the "BCP" codes.
all drivers in device manager seem to be working aswell.
specs are:
Windows 7 ultimate 64 bit
evga x58 classified 3 mobo
6950 direct cu2 2gb
600 watt ion2 power supply
intel i7 950
12gb ddr3
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 1e
BCP1: FFFFFFFFC0000047
BCP2: FFFFF80002F08590
BCP3: 0000000000000028
BCP4: FFFFF880045654A4
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\092611-30841-01.dmp
C:\Users\connzy\AppData\Local\Temp\WER-67673-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
alright so i realized what part of the error code to search for in google turns out its a program or driver thats giving me the BSOD.
ive already look through device manager and theres nothing that isnt working properly so is there another way to find out what program isnt working.
the codes wont help you, because its most likely caused by a hardware issue and not a software one.
whats the actual message you get when it BSOD's
Is there a pattern to when the BSODs occur?
For instance, is it usually under heavier system load when gaming?
Or when you are using a specific application?
Intermittent BSODs can be a real PITA to troubleshoot, so you need to start keeping a close eye on what your system is doing when it happens.
the last time it happened i was only using firefox, the time before that i was using 3dmark11 to benchmark my gpu.
the last time it BSOD i managed to write down 1 word which was dxgmms1.exe <- the error was about that it might of crashed or something?
when i googled that i found out its direct x 11 thats fucking up.
So im in the process of trying to download and install directx 11 again but because its like built into windows 7 i cant find a way to re install it?
EDIT:
alright i just got another BOSD this time it said the error was to do with ATKDisplowfilter.sys.
quick google search of that and i get hundreds of pages about how a program called gamerosd that is installed with the ASUS mobo drivers just ***** everything up. so i just went though the program files and deleted this program that i didnt even want anyway, hopefully this has put an end to all these BSOD's.
