Help! With using two monitors, my refresh rate keeps changing
4 (0.00/day)
Processor Ryzen 5800x
Motherboard MSI X570 Tomahawk WIFI
Cooling NH-U12A chromax.black
Memory 32 gb 3600 CL14
Video Card(s) Asus Rog Strix 3080 OC 12
Storage Samsung 970 pro M.2
Display(s) Asus Tuf 1440p
Case Torrent RGB
Audio Device(s) Soundblaster AE-7
Power Supply Seasonic GX-1000
Mouse Corsair Sabre
Keyboard Corsair
I need help with a problem I have with two monitors connected at the same time to my system. One problem is with my refresh rate changing to 60hz from 144hz, when my two monitors come back from either a screen time out, or from being locked and coming back on. Additionally, sometimes content/apps or a browser that was on monitor 2, the browser will be halfway across monitor one. Monitor two is a Dell S2721QS 4k 3840x2160 connected via HDMI Monitor one is ASUS VG27AQL1A 27 1440P connected DP. GPU Asus Rog Strix 3080 12gb. I have the latest drivers, etc.
Any additional thoughts or trouble shoot steps I could make. Also, why the Dell is connected via HDMI and not DP, is there is only one DP on the monitor, and it's attached to my work desktop when I am not using it for my personal time.
Edit On that system it's the ASUS monitor not the ACER 27" XB273U GX. The ACER 27" XB273U GX is downstairs
4 (0.00/day)
Case Torrent RGB
Mouse Corsair Sabre
Keyboard Corsair
Is the Acer not 165Hz? And the Dell is 60Hz.
Could you try moving the HDMI to the work desktop and DP to the gaming computer?
The work PC is a HP deskpro 600, and does not have a HDMI port. So, I can't switch them. Also my mistake on the monitor, it's not the ACER, it's an ASUS TUF 27" 144hz
thank you
Ruru
S.T.A.R.S.
13,780 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
Try to OC the 60Hz one to 72Hz or put the 144 one to 120Hz.
tabascosauz
8,305 (2.31/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
I had this same issue a couple weeks ago on one of my monitors (S2721DGF + M32Q) after hurriedly buying a cheap no name DP cable from Best Buy. Sometimes the Dell would just randomly switch to 60Hz (and sometimes even lacked the option for 165Hz in Windows). I switched back to my two better DP cables (one 1.2 Dell from the S2721DGF, and one 1.4 cable from Cable Matters), and no longer have the problem.
As for the window placement when disconnecting/reconnecting monitors, Win 11 should be having less problems but it's not perfect, especially if you run different scaling, or have older games that don't alt-tab very well, or force Fullscreen option in NVCP. Win 11 should have an option to remember window positions under multiple monitors settings.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
If you use duplicate, the refresh rates are forced to match
Only extend works with different resolutions and refresh rates
DP is a lot better than HDMI when it comes to sleep/wake since it's a hotpluggable connector, you may actually be able to fix the problem with a cheap DP to HDMI dongle
In win11, i've been able to just hit F5 and refresh the desktop to get icons where they belong - but windows will move to an active monitor to prevent them getting lost if one has failed to wake up from sleep
4 (0.00/day)
Case Torrent RGB
Mouse Corsair Sabre
Keyboard Corsair
Thank you
I will take a look at the cables too. Thank you
F5 does work, I have been doing that or the Windows key. I forgot to say my taskbar is gone also when its like that. I am going to look for a HDMI to DP connector, now that you mention it. Thank you,
