High FPS but feels extremely choppy and not smooth
Risk
5 (0.00/day)
I need help! So, basically I play fortnite and I stream it. When I DOnt stream I get 240fps consistent and feels super smooth just like how 240fps should feel like. I have a 240hz monitor btw. BUT then when I stream I cap my fps to 180fps and up on top on the fps counter i still get consistent 180, but omg it's soooo laggy/choppy. I really don't know what to do. I really wanna stream. I've even reformatted my entire PC and I have my obs settings to 2000 bitrate and 720p60. I have a decent enough pc that it should be smooth when I play. It really affects my gameplay and the mood and ruins the stream.
My pc specs-
CPU - I7 8700
CPU COOLER - Cooler Master Masterliquid ML240R RGB
RAM - ADATA XPG 8GB× 2
GPU - MSI RTX2060 SUPER GAMING X
Motherboard - ASUS ROG STRIX B360H
Storage -
1. Kingston 240GB A400 SSD
2. WD 1TB
PSU - 1st player DK 6.0 600W
CASE - NZXT H500I
I hope you're using NVEnc instead of CPU! I usually get playable FPS and the videos at a proper framerate. Turing's NVEnc is supposed to be superb! (Even on GTX, if it's the 1660 Super)
Even on CPUs with enough cores, OBS with x264, can be tricky, even for me!
I use Nvenc new but I really can't wrap my head ard this problem... I'm familiar with everything like making sure the monitors have is set to 240hz.. making sure all graphics drivers are updated. And mobo drivers as well... wait ACTUALLY while writing this I realised that I haven't updated my bios could that fix anything?
What bitrate do you have it set to in GeForce Experience, if using that? IIRC, a workaround to try, is to raise the recording bitrate by some.
On geforce experience it's 20 bitrate. But how does that affect I only use geforve experience to clip some of my gameplay
Should be fine now. IIRC, I saw something like that with less than 10 Mbit or at 10 Mbit.
But I still have that problem when I stream... suoer laggy and chppy
Hey guys figured out why... before u stream there's an option to use OPTIMIZED SETTING FOR FORTNITE... I had it ticked... I untitled and my fps is stable and everything running smooth
