Home "server" CPU choice. Threads VS Cores
Upgrade?
  • i7-8700
    Votes: 3 30.0%
  • i7-9700
    Votes: 7 70.0%
  • Total voters
    10
75 (0.09/day)
System Name Desktop + SteamDeck OLED
Processor i7-10700K @ -0.130mV offset
Motherboard MSI MPG Z490 Gaming Edge WiFi
Cooling be quiet! Pure Loop 280mm
Memory Corsair Vengeance RGB Pro 32GB 3200MT/s CL16
Video Card(s) RTX 3080 Ti Founders Edition @ 1830MHz, 800mV
I have the opportunity to upgrade my home server from i7-8700 to i7-9700 for free and I'm wondering if it's even worth my time to swap them.
It's just a Windows 10 Pro system that I use as a basic file share, Minecraft server host and maybe some other things in the future like Plex
I'd be gaining a little clock speed and cache but really it comes down to 6 core 12 thread vs 8 core 8 thread, will the 9th gen be faster?
So for my use case, what's your guys opinion? I'll put a poll but comments with insight would be awesome too
Down the line if I upgrade my personal rig its 10700K will probably end up in the server too anyway
Toothless
Tech, Games, and TPU!
9,816 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
No point in changing unless your use case requires it. For what you listed either chip would work but if you're switching down the road anyway, no reason to change.
5,488 (3.65/day)
Colorado, U.S.A.
Software Windows 11 Home
I'd do it, but because I like messing with technology.
75 (0.09/day)
So do I, so it would be a fun adventure! I like to undervolt as well and the 8700 wasn't a very good bin, so this gives me another chance at the lottery too. But if the 9700 is no faster in the end then it is a little silly
Toothless
9,816 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
MC server is single thread for the most part. You're one generation newer with no use for extra threads. Even if you run four vanilla servers you'll be ram limited before the CPU sweats.
Source: I have two vanilla and three modded servers for friends.
501 (0.51/day)
System Name Firestarter
Processor 7950X
Motherboard X670E Steel Legend
Cooling LF 2 420
Memory 4x16 G.Skill X5 6000@CL36
Video Card(s) RTX Gigabutt 4090 Gaming OC
Storage SSDS: OS: 2TB P41 Plat, 4TB SN850X, 1TB SN770. Raid 5 HDDS: 4x4TB WD Red Nas 2.0 HDDs, 1TB ext HDD.
Display(s) 42C3PUA, some dinky TN 10.1 inch display.
Case Fractal Torrent
Audio Device(s) PC38X
Power Supply GF3 TT Premium 850W
Mouse Razer Basilisk V3 Pro
Keyboard Steel Series Apex Pro
VR HMD Pimax Crystal with Index controllers
Yeah. Our modded MC server eats 48GB at a little bit higher than normal load.
Luckily we don't have any others MC servers other than an Space Engineers one that is much less played.
Honestly a vanilla server with like 6 people can be ran on pretty much anything. As long as it has 16GB of ram.
9,804 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
The 9700 will be faster.
Toothless
9,816 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
I've had four servers up at once with around 64GB used. Server runs 128GB and octo channel so the only issue comes down to core clocks. I've been tempted to turn my 5950x into a game server server.. server.. thingy since I did get 128GB to work but that's more power to the bill.
501 (0.51/day)
Processor 7950X
Cooling LF 2 420
Mhm, we run my 7950X because the single core is so important that 64GB is a lesser bottleneck. (Heavy mod moment)
Once I get a new 9950X3d or whatever it will be called I'm making a "proper" server rig with 128GB ~4800MHz ram and undervolting/ecoing it.
Toothless
9,816 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
I have a dual 2698v4 since I was going multipurpose like file backups, BOINC (when it's cold out) and other things. Sure I could use the 3900x but certain things are limiting that.
895 (1.84/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
It's up to you. Either case is well within reason on a desktop purposed as a light duty server.
A single game host sounds wonderful for such a generation of hardware even if it's just block game.
When I chose a server, I wanted to retire my Pentium 4, Phenom II X4 and FX-8370. Repurposed a light duty desktop, gave it Server Core and tossed two giganto multi-TB HDDs at it with an SFP for direct workstation attachment.
Threads? Cores? I chose neither. All that matters to me is 24/7 availability and the ability to allow general user access.
If you're doing VMs, PiHole, Plex and a bunch of other stuff of that nature, you most certainly need nested virtualization technologies, which I don't need or use. You've had this technology since before the first generations of the i7. The performance you have with block game depends on the server software which is typically single threaded so single core speed would be the most driving factor influencing that decision.
Looks good to me. My 3600 would be a great candidate.
Use of multiple adapters, good memory and enhanced storage also play a part. Especially when any of it is misbehaving repeatedly.
If you use any HDDs that are starting to go south, there may be random performance hits, so that's a tell. Bad config files might also still be a thing.
This game was created in an era where I could switch back and forth between my high school era Pentium 4 Prescott and a Phenom II X4 so I'm sure it's fine.
1,287 (0.74/day)
System Name Gamey #2 / #3
Processor Ryzen 7 5800X3D / Ryzen 7 5700X3D
Motherboard Asrock B450M P4 / MSi B450 ProVDH M
Cooling IDCool SE-226-XT / IDCool SE-224-XTS
Memory 32GB 3200 CL16 / 16GB 3200 CL16
Video Card(s) Red Dragon 6800 XT / Eagle 3070
Storage 4TB Team MP34 / 2TB WD SN570
Case Corsair 4000Air / TT Versa H18
Power Supply EVGA 650 G3 / EVGA BQ 500
FWIW, I did a lot of research for *non-server* desktop performance when getting an upgrade from my i5-8400 with the 2 CPUs you're comparing here and found the i7-9700 to be the better performer after reading and watching a lot of reviews. Buuut it wasn't a huge difference. Also fair warning if your i7-8700 is a good sample and runs relatively cool and low power, my 9700 is the opposite of a golden sample (a brown sample) and uses more power and runs hotter than I would have preferred, even when restricting to the i5-8400's clocks and cores. It dukes it out with one of my two Ryzen 5 1600AFs for being my brownest CPU sample. You hopefully will be luckier.
13,956 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Free is good. So if you don't need to spend money to upgrade the motherboard, RAM or PSU to support the 9700, then why not?
75 (0.09/day)
Well folks I did a BIOS update and dropped the CPU in. Ran Cinebench to do some validation and I am getting some very strange behaviour, clocks and voltages are all over the place, and as such it is performing worse than the 8700.
I'm going to dig in to it more tonight, reset the BIOS, wipe ThrottleStop config etc to see if anything is interfering with stock behaviour
Motherboard is an Asus Prime B360M-A
My 8700 was an ok sample I think. I undervolted it to -0.050mV which is pretty standard but didn't try for any more. Temps were ok but it was under an OEM acer cooler that I saved from eWaste so that's not very representative. Excited to dial in the 9700 if I can get it running right. So far it looks like the 8700 idles 1-2W lower though
1,428 (0.79/day)
I voted for i7 9700. You get 8 real cores, never mind the hype about threading with 8700, so it's faster and with both being 65W parts it's a pretty sweet upgrade.
Here's a comparison from CPU world.
Edit: I'm sorry - didn't read the whole topic before posting - I'm sorry to see that you've been having problems with i7 9700; if they continue, just put i7 8700 back in and have peace.
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Maybe you just discovered why it was free.
75 (0.09/day)
Maybe you just dicovered why it was free.
A great point, but it's actually a from workstation that was retired a week ago that came in to work and we're going to repurpose. Asked my boss if I could trade him CPUs, so it *should* be good. It came out of an identical Asus Prime B360M-A too
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Well, if it was working before it was retired, then yeah, seems it should work.
dgianstefani
TPU Proofreader
5,496 (2.05/day)
Swansea, Wales
Benchmark Scores Legendary
For free it's an obvious choice, the i7 9700 will run cooler due to soldered TIM and provide slightly more performance.
CPUs without HT don't have the associated security holes either, so patches to mitigate those holes don't slow them down.
3,733 (1.77/day)
Power Supply Corsair RM750x
Mouse Logitech M575
More threads are more useful. I'd keep the threads but still get the free CPU to sell for cash.
Good points. This has changed my mind.
