how can i bypass the power on password on a dell latitude c600?
675 (0.10/day)
Michigan, US
System Name Clarise
Processor AMD Athlon 64 X2 4200+ (Toledo) @2.8 (255 X 11)
Motherboard Asus A8v Deluxe rev 2
Cooling Gigabyte 3D Cooler Pro + 5 Case Fans
Memory 2GB G-Skill (2.5-3-3-6 1T) @ 467mhz
Video Card(s) XFX 7600GT 256MB GDDR3 @ 640-814
Storage Western Digital WD5000AAKS 500GB (Sata) Maxtor 120GB (Sata) Western Digital 120GB (ide)
Display(s) 19" HP Pavilion M90 / 33" Sony Wega Trinitron
Case Antec Lanboy with a few mods :0)
Audio Device(s) Creative Audigy 4 Pro - Bose Free Style 2.1 Speakers
Power Supply Rosewill Extreme Edition 500W 34A 12V rail
Software Windows XP Pro & Vista Ultimate
hey a friend of mine just got two laptops (dell latitude C600's) old but will run xp ok. anyway one is for parts and the other runs fine. he gave them both to me to fix a overheating issue and i noticed that the "parts" computer has a slightly faster cpu a whopping 850Mhz :D anyway the parts mobo has a power on password and i cant get past it. they were old office computers from his girlfriends job that they were given. but there is no way to find out who the laptop belonged to to get the password. here is a screenie.
Reset CMOS?
there isa long thin green battery by the ram that i unplugged but as far as a clrtc jumper or short i cant find anything.
did you try the reset hole some where underneath?
Harddrive password ,then replace the harddrive
try clearing the bios by removing a battery, on some comps the circle battery is under the slot where the big battery goes, so you have to remove the battery to access the small one.
i removed the main battery. if you look at the first pic the only thing on the computer is the mobo keyboard and monitor. i removed all plastic, hdd, cd rom, battery...everything. and still a no go. i left the green cmos battery unplugged over night too.
I had an Inspiron with the same problem. The ONLY thing I could do was call DELL :banghead: If you can get through, the will ask all sorts of questions, I assume to make sure it isn't stolen. I did get the "Master Key" from them and was up and running. I think there is some sort of firmware burnt in with the password, and clearing CMOS will not get rid of it. You will need the system service tag.
