how can I connect 6 Pure 12 aRGB fans if I can't use the TT SYNC Controller for them!
102 (0.07/day)
I heard the TT SYNC Controller is not compatible with Thermaltake Pure 12 ARGB .. NOT the plus edition but Thermaltake Pure 12 ARGB regular ones. What if I already have both aRGB headers on motherboard occupied. How the heck will I be able to install 6 more of the Thermaltake Pure 12 ARGB... I was thinking to get a HUB for them, but then again are they proprietary and will not work on a hub!? how crazy?!
6,678 (1.59/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard Beelink/AZW SEI
Video Card(s) Iris XE
Storage WD Black SN850X 8TB m.2, Seagate 4TB SSD + SN850 8TB x2 in an external enclosure
Display(s) 2x Samsung 43" + 1x 32"
Audio Device(s) No-name compact bluetooth speakers
Power Supply 65w brick
Mouse Logitech MX Master 3
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Why in the F would they make their own controller not compatible with their own fans or vice-versa.... seems like a really stupid idea to me, as well as a very quick way to lose/piss off customers too :)
Have you contacted TT to ask why this is so and/or if there is a solution/work-around ?
This is just ANUTHA reason why I call a lot of the silly light-up stuff "R.friggin.G.friggin.B.friggin."
931 (0.63/day)
Yeah, your best bet is to contact Thermaltake and ask them. There should be some kind of workaround.
108 (0.04/day)
Processor Intel® Core™ i9-13900K Processor
Motherboard ASUS ProArt Z790-CREATOR WIFI
Cooling EKWB EK-AIO 360 D-RGB
Memory Corsair VENGEANCE® RGB 32GB (2x16GB) DDR5 DRAM 6600MHz C32 Memory Kit — Black
Video Card(s) EVGA GeForce GTX 1070 FTW GAMING
Storage Samsung 1TB 990 PRO
Display(s) ASUS ROG Swift PG279Q x2
Case Lian Li O11 Dynamic EVO
Audio Device(s) Corsair VOID RGB Wireless Premium Gaming Headset
Power Supply Corsair RMi Series RM850i High-Performance ATX Power Supply
Mouse Corsair SCIMITAR RGB Optical MOBA/MMO Gaming Mouse
Keyboard Corsair STRAFE RGB Mechanical Gaming Keyboard — CHERRY® MX Silent
Software Microsoft Windows 11 PRO
You can use A-RGB Splitter Cable and connect those fans directly to the mother board ( The picture is for 6 way a-rgb splitter cable, there are other options with fewer headers like 2 3 4 5 way splitters. ). Only problem is you might not line up a RGB pattern like a hub does.
Those fans should come with a proper Mainboard Signal Bridge Cable, so could be used with motherboard RGB headers.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
I have 5 thermaltake fans gifted to me here, because the owner sold the cables to the controllers with his old case
you cant even buy their controllers seperately, absolute E-waste products
102 (0.07/day)
There's also a Pure 12 set. TT packs in a controller, but you only need one - three pin header on the motherboard to drive lights and to control the fans, some Gigabytes don't, 4 pin motherboard headers do not work. The controller comes with THIS KIT - but there are different packages available. If you haven't purchased any, you might want to get a 3-pack.
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Yep! I got 3 of them, no controller. Only option is to cut the wires and spice in actual fan headers.
