How do I calculate TDP?
hat
Enthusiast
21,754 (3.23/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
I would like to calculate the TDP of my processor. It's 65w at 2.8GHz 1.425v, but I want to see what it is at 3.5GHz 1.40v.
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
9,899 (1.66/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
You could find out the heat dissipation properties of the heat-sink your using and then work out how much extra heat the processor is putting out using mathematical reverse engineering?
There's probably an easier way but that's just first thing off the top of my head !
*edit* for example the link posted above is a much more efficient method! ha ha
hat
Enthusiast
21,754 (3.23/day)
Ohio
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
It says 186 for my OC'd Q6600! Yikes! I dunno how accurate that site is, but it's the easiest way to find it I could google up! :D
At least in my application I would assume that's way higher than I ever load my CPU, but my Xiggy + Scythe Kaze keep the temps in check.
sweeper
796 (0.11/day)
SW, Ohio
System Name "X"
Processor AMD PHENOM II X 6 3.2GHz @ 3.6GHz
Motherboard ASUS M4A785-M
Cooling ARCTIC COOLING Freezer 7 Pro Rev.2
Memory Kingston Hyper X DDR2 1066 2X2 - 4GB
Video Card(s) SAPPHIRE Radeon HD4870 1GB 256-bit GDDR5
Storage Western Digital 500GB SATAII Black / Western Digital My Book Essential External HDD 1TB
Display(s) Soyo 22" LCD / Vizio 32" LCD
Case Thermaltake Xaser II Full Tower
Audio Device(s) ON-BOARD VIA VT1708S
Power Supply Antec Basiq 550W Plus Modular
Software Windows 7 Ultimate
119w ... not bad. Less than my brothers Phenom @ his stock speed. :toast:
hat
Enthusiast
21,754 (3.23/day)
Ohio
Neat program, lots of potential, but needs lots of work. Doesn't even support PII or i7 yet.
9,899 (1.66/day)
Essex, England
System Name My pc
134w for my current setup
Calculated the wattage of my old Phenom x4 905e @3ghz and got 68w!
Shit damn :D
( 1.1 volts for 3ghz vs 1.2 stock)
