How Do I Change Single Player FOV in MoH 2010?
646 (0.11/day)
South East, United Kingdom
System Name Swag
Processor Intel Xeon E3110 4GHz
Motherboard GIGABYTE GA-G31M-ES2L
Cooling Scythe Infinity I Push-Pull w/ AS5
Memory 2x2GB Transcend 800MHz DDR2 @ 890MHz 1.9v
Video Card(s) Palit nVIDIA GTX460 1GB 800/1600/2000
Storage Crucial M4 64GB
Display(s) LG Flatron M1917TM 1280x1024 @ 60Hz
Power Supply OCZ StealthXStream 2 600W
Software Windows 7 Professional 64-bit
It's really freakin' annoying to have to play so far zoomed it that the game was made for some little kids or something... everybody knows how to find the setting to edit multiplayer FOV but I've scoured various searches and can't seem to find how to tweak the FOV in single player.
MOH SP uses Unreal Engine 3 for single player. Frosbite for multiplayer. From what I recall, in order to change the FOV for UE3 games you needed some sort of FOV hack. You will need to check the modding scene to see if someone is working on it. There was a guy who had a website called widescreen fixer that would fix such a problem in games. But there is no fix for this game. He does post over at the widescreen gaming forums. Or you can email him but I doubt he will do it.
Urgh... man I'm so glad I didn't buy this game. What a waste of money that woulda been :/
I refuse to play it when it looks like that, might as well buy an Xbox
My post wasn't intended to mean there is a FOV problem. Just that in order to adjust FOV you need to either mod it or get a FOV hack.
Hmmm have you played it? There definitely is a problem... it's so zoomed in I can't even play it
It hard to answer your question when you say you didn't buy/play then imply that you have. You have this weird back and forth thing going on.
I played the start of the 1st mission for about a minute and then quit
I downloaded the game to test it before I picked it up, cos I had it on pre-order but with GAME you can pre-order games without being under any obligation to pay for them until you pick them up, if you so choose.
So I choose not to, cos this thing sucks dick.
