HOW do i prevent Windows 10 from changing default audio output device when i connect a device to my PC?
649 (0.11/day)
Norway, which means Amazon is not available...
System Name Winter v3.2024
Processor Intel i7 12700K (since november 2021)
Motherboard Gigabyte Z690 Gaming X (since november 2021)
Cooling Air Liquid Freezer II 360 with LGA1700 kit (since november 2021)
Memory Crucial Ballistix 2x16gb 3600mhz C16 (since november 2021)
Video Card(s) Gigabyte RTX 3060 Ti Gaming OC Pro LHR - Rev3.0 (since july 2022)
Storage 1x 1TB WD Blue SN570 SSD, 1x Seagate 4TB SATA
Display(s) 1x 55" LG C1 4k OLED, 1x Gigabyte 32" M32Q and 2x AOC 27" CG1
Case Fractal Design Define R6 (since 2018 and still working like a charm!)
Power Supply Corsair RM850x black (since august 2022)
Mouse Razor Deathadder v2 (since december 2021)
Keyboard Varmilo VEA109 v2 MX Silent Red (since august 2022)
What a frustrating problem this is! I have some game controllers that gets detected as audio devices whenever i connect them to my PC, changing from my default audio device.
See on the below screenshot. Realtek audio is what should always be my default audio device, but somehow, it keeps on changing. HOW do i PREVENT that from happening?! Is there a way to prevent that from happening, or? I tried googling, but that gave me no clear answers.
18,584 (2.63/day)
System Name AlderLake
Did you try removing the controller from the devices?
Then reconnect?
Clibanarius
20 (0.02/day)
I used to have this EXACT issue with my Dualshock4 any time it'd power down or otherwise be disconnected from active mode. Presuming you have some sort of wireless controller or Dualshock4 or something with a jack for audio, which it seems like you do:
Plug in controller and get everything recognized, should take like 1 second of waiting. Fire up Device Manager. Go to "Audio inputs and outputs", find the controller's entry and right-click, disable. That should carry through and override its activation when you plug it in next. You can probably just do that right now to make sure it doesn't interrupt the audio and change playback devices again. If so, you're set!
649 (0.11/day)
It looks like that did the trick! Thanks so much for the help! :) And yeah, it's the DualShock4 that i am using, but with a connceted usb-cable.
342 (0.18/day)
@Ferather - would be useful in a simple tool.
And FXConfig is a virus. You might have to update your tutorial and stuff (if ppl still use it). Since the TjingTjong did APO Driver too.. they are both infected. You only removed Pihto Patcher...
I have the (original) version of FXConfig that showed that it's using AutoHotKey and overdisplays your Windows GUI. Overwrites it. Then the TjingTjong-Un can read what you are doing. Multilingual.
But the OG FXConfig also shows what proxy website they are connecting too.
Time for some überültra reverse engineering. ❤
3,155 (1.97/day)
United Kingdom
Open the Windows sound panel, and select the 'playback' tab. Connect all the devices, now select your primary output 'Set Default'.
If you unplug a device and plug it back it, it should not change, however, you can also right click disable it.
As you can see disabled devices do not show as outputs.
