How do you get Cinebench2024 to work with amd gpu's?
AMF
721 (0.49/day)
USA
System Name MR T System price $2464
Processor Ryzen 9 3900x 325$ 4.725Ghz boost pbo +50+75 enhance .1875.-+offset auto voltage -.2500 offset soc
Motherboard ROG STRIX X570-E Gaming $ 125 open box
Cooling 280mm ARCTIC FREEZER II idle temps 25c cpu 28c cpu diode 20c vrm 25c motherboard b stock 60$
Memory 2x 16GB Dual rank G Skill Trident Z Neo F4-3600C16-16GTZNC @3800 1.405v 16-19-16-19-35-54-1T $96
Video Card(s) Asrock RX 6950XT Oc formula 705$ pcie4x16 2599 min 2699mhz 2799boost 1110v 2392mhz mem 19GB/s
Storage 500 GB WD SN850 PCI-E 4.0x4 85$ pcie 4.0x4
Display(s) Vizio M50QXM-K01 4k@120hz 2.5k 120hz 2k@240hz $448
Case Cougar Panzer Max G Full Tower Tempered Glass 150$
Audio Device(s) Vzio M51a 5.1 Soundbar Dolby Atmos goodwill 45$!!!!
Power Supply Seasonic SS-1250XM2 Bought in 2013 350$ 11 y/o hasnt lost any voltage or watts
Mouse Perixx eRGO wireless Trackball 25$ 2000dpi
Keyboard Corsair K57 50$
VR HMD Dont give a damn about vr
Software win 11 pro modded by me no ai no remote connections free hehe
Benchmark Scores 8188 multi 540 single cinebench r20
just closes program..... no warnings
Also crashes here when starting the GPU benchmark with a RX 6800XT
Did it report an error in Windows Event Log?
It worked for me with rx 5700. I thought I was using Driver 23.8.1 but I just noticed that Windows must have switched my drivers again because I'm missing a lot of options in the AMD driver tool which always happens when it does that :banghead: .
It seems that some GPUs got more testing than others:
Funnily, it even supports GPUs that haven't been released :laugh:
Works with 6650XT but hangs when you try and run more than 1 test, have to close and restart.
It prefers Cuda.
Worked but once it finished the driver needed to reset. All stock settings.
Did a clean Windows 10 installation on 26th of August but forgot to turn off the automatic driver update of Windows....
Used DDU, disable automatic driver update and then installed Adrenalin 23.9.1. Issue is solved :)
@A Computer Guy
Thanks for the TIP!
i deleted cinebench 2024 extracted to desktop this time and installed and it works defragged trimmed ssd
