How do you proceed to remove old sticky thermal pads ?
1,294 (0.17/day)
Hello,
I bought 2 adaptec RAID cards and those babies can run pretty hot (70°C / 160°F) even with decent case cooling.
That's why i decided to clean the main chips and apply a new thermal compound layer.
The thing is, Adaptec used those pink "gum like" thermal pads and it's a real pain to remove completly / properly. So far i did my best to remove most of the dried pad using a cutter's sharp edge across the surface, and 98% came off nicely. The remaining 2 % is still sticky and leave a thin layer all across the heatsink and the chip.
My question is, how do you deal with thermal compound removal in order to restore the flattest & cleanest surface possible ?.
Thanks in advance for your advices.
edit : added picture
Try 91% Isopropyl Alcohol, first. http://www.bing.com/images/search?q=91% alcohol&qs=n&form=QBIR&pq=91% alcohol&sc=8-11&sp=-1&sk=
Denatured Alcohol, second. http://www.bing.com/images/search?q=denatured+alcohol&FORM=HDRSC2
Did you try softening with a hair dryer?
On the heatsink side, one oil will often be dissolved by another, so try WD-40, olive oil, vegetable oil, etc..., then use alcohol to clean off the oil.
Electric cleaner: http://www.bing.com/images/search?q=Electrical+Parts+Cleaner&FORM=RESTAB
I removed those bubble gum paste mostly with friction and a high concentration isopropyl alcohol that is above 90%. High concentration isopropyl alcohol is a type of degreasser to clean circuit boards. It hopefully can "eat" through the oil of the thermal paste.
Edit: You can a huge sealed tin of isopropyl industrial degreasser. Their 99.8% pure but I would always dilute them
For bubble gum like that you would need a micro-fiber cloth or you can use your fingers to keep rubbing the surface to create enough friction to flake the remaining bubble gum paste.
Thank you so much for your replies. Not only was it helpfull, but also informative (didnt know for the oil)
As long as it isn't powered up you can use soap water n a scrubby pad, rinse well then drip dry. Be amazed what I have washed in a dish washer, mother boards, video cards, etc.
acetone does miracles. just soak it for awhile and then scrub it with a plastic card and remove leftovers with a toothbrush
Heat gun, then fingernail polish remover (acetone) after it cools of course. Just be careful with it. It will damage plastic
I use gasoline sometimes....
