How long to scan based on software and hardware
2,957 (0.65/day)
Fort Worth, TX
System Name LGA775 | BoX-Server
Processor Xeon E5450 OC3.6GHZ from 3GHZ | i3 3.4GHZ
Motherboard ASUS PQ5-EM | ASRock
Cooling 120MM Heatsink (2-FANs) | Custom HSK 90mm
Memory DDR2 2GB-x4=8GB | 8GB 2x4GB=8GB
Video Card(s) NVIDIA Quadro K2200 4GB | Intel
Storage 500\500/240/240GB SSDs 120GB Laptop IDE
Display(s) Asus 24"
Case DIYPC N1e-SPORT | CoolerMaster 110
Power Supply EVGA 550WATT | Rosewill 530WATT
Mouse Rosewill RGB
Keyboard Rosewill RGB
Software WiN10ET/WiN11ET
Hi guys,
So I'm scanning with SUPERAntiSpyware and so far at 1HR and 20min still counting...
I'm using a HDD and going to upgrade soon. Just wondering how long it takes to scan for you. I know some Malware programs scan differently as I'm scanning with SAS and MalwareBytes next [got some spyware here] :twitch:
I know it's smarter to go into safe mode but my usb keyboard doesn't seem to work once the screen comes up to push 4
Depends on the type of scan, the number and kinds of files, and the performance of the drive. I've seen scans take 4-6+ hours before. Quick scans usually run closer to a few minutes. Let it run its course. I always enable MBAM and other software to inspect containers (ZIP, RAR, 7Z, etc), and to perform deeper scans, even if it takes substantially longer.
Do you know what malware you've been hit with?
What are you running as your live AVAM (Anti-Virus Anti-Malware) scanning solution? Windows Defender? Or is your MalwareBytes a Premium version?
MLB (MalwareBytes) free, SAS (SUPERANTISPYWARE) And AVAST! and unsure of what it is but I'll clean it up
You need to provide more information.
The size of the drive does not matter. The amount of data and number of files on the drive does.
As Kursah noted, it also depends on the type scan you selected, quick or full. I just ran a Quick scan and it took 1 minute 8 seconds. A Full scan took 8 minutes and 35 seconds.
But it is important to note much also depends on your hardware. Scanning a SSD is much quicker than a HD, for example.
Make sure you clean out the clutter before scanning either with CCleaner or Windows own Disk Cleanup. SAS is good at reporting simple cookies as Tracking cookies. It is critical to note that most tracking cookies are not bad. Plus, scan go faster without all the clutter.
MalwareBytes seems to be better at finding more then SAS. Think I'll use MalwareBytes more. All is scanning for now... (will post results soon)
I used MalwareBytes back In 2008 so
What usually do this and LINK
So what is probably two hours for you will be 3-4+ for me. All depends on the amount of data.
