How many components can my MCP35X pump handle?
1,770 (0.35/day)
Cussing desert
System Name Torquey Vulture
Processor Ryzen 5 2600
Motherboard Gigabyte B450 MiniITX
Cooling DDC water loop, EK block
Memory 16GB Patriot Viper RGB
Video Card(s) EVGA 1070
Storage 500gb NVME; some Phat HDDs
Display(s) Achieva Shimian 27" 2560x1440
Case Thermaltake V1 MiniITX
Power Supply EVGA supernova 850 G2
Mouse Corsair Harpoon
Keyboard Possibly the cheapest you can buy. Shift key broke recently. Space sounds like I'm kicking a ham
Just a quick question. Ive got a EK cpu block, EK full cover gpu block and a 360 rad, and im adding a 120 in a few days between the cpu/gpu. Can my single MCP35X handle that? I'm thinking it should be able to, but i just want to get an opinion or two.
Thanks,
Irony
Yes, for sure. That's a strong pump. I've used lesser pumps for pretty much the same configuration. :toast:
Ok, thanks. I just wasn't sure if it was up to the task. Thats really all I was looking for, now i can rest assured knowing it isn't overstressed.
my MCP35X pumps trough:
one XSPC Raystrom CPU block
two XSPC Raystrom GPU blocks
tree male and tree female Koolance VL3N QDC
one Watercool MO-RA3
and approx 2 meters of 13 mm ID tubing, this is on 0 % duty cycle on the PWM control, CPU never over 55 C.
If you really want to get into the nitty gritty with what your pump will handle take a look at martins reviews
http://martinsliquidlab.org/2011/02/25/swiftech-mcp-35x-reservoir/
for the question you asked you'd be looking at pressure drop vs flow rate
He has reviewed quite a few blocks and rads as well that you can take numbers from, this will basically give you an idea of how strong your pump actually is vs the components in your loop and give you the lowest possible pwm setting you can set with the best possible temperatures
It's the absolute best performing "non-extreme" single-pump out there... Better pressure and even flow than a D5 in most loops, and thanks to the PWM, it's just as silent. I never understand people who think they're "loud"... Sure, they make a "water rushing" sound, but only if you don't plug the PWM header in and set up a decent profile!
Currently running an MCP35X2 (which was originally two separate MCP35X pumps that I bought the white MCP35X2 top and HS for), and I get about 1.2-1.5gpm flow through an Apogee HD (one of the most restrictive, yet best performing, CPU Blocks), MIPS R4E Ni/BLK Motherboard VRM and SB Block Kit (two separate blocks), two Heatkiller GPUx3 680 Hole Edition GPU blocks in serial, Heatkiller "Core" GPU Block + MOSFET add-on for GTX650Ti Boost PhysX/Folding card, an XSPC EX420 radiator, an Alphacool NexXxoS UT60 240 and 560 radiators, a NexXxoS XT45 140 radiator, 2x "High Flow" flow rate sensors, 6x in-line temp sensors, and a total of 36 rotary angled adapters and 22 rotary angled compression fittings, about a 50/25/25 split of 45deg, 90deg dual-rotary, and 90deg single-rotary Bitspower fittings.
Tubing is 1/2x3/4 Primochill Advanced, actually have two reservoirs: an EK Multioption X2 150 Advanced that I use both for looks and because having it just before the Dual 5.25 Bay Res helps eliminate the issues that bay reservoirs have with bleeding/bubbles; the MCP35X2 is connected directly to the output G1/4 port of the bay res via BP 90deg single-rotary adapter and male-male rotary coupler.
I tried using two D5's, specifically Alphacool VP655's, and never managed more than 0.7gpm. The MCP35X2 has never once had to exceed "50% PWM Duty" to maintain the 1.2-1.5gpm, either!
Seriously, get the heatsink!!! Also, if you have room, get an 80x15mm fan (I have a Vantec, a Noiseblocker, and a number of Delta/Sanyo Denkei/etc; Vantec is within 2C of the 8000rpm Delta, but is, well, literally silent in comparison).
Without the heatsink, the pump base can get quite hot; over 55-60C. With just the heatsink and only barely a breeze of airflow across it, the PCB temp dropped to 41C max, and with the fan it now has never exceeded 31C! That's basically doubling the life of the pump right there, and for $13-23 depending (single-pump model is cheaper, but you can't use two single-pump models for the 35X2), and $8-13 for the fan, it's absolutely worthwhile.
DDC pumps, unlike D5's, are cooled by air as the electronics are physically separated from and never make contact with the electronics. So, while a D5 can add up to 38W of heat to your loop (or two can add as much as a CPU!), the DDC's like the MCP35X add no heat to the loop, they only help you to remove it!
Lol, you got pics? Now I wanna see your loop lol.
Didnt know about the heatsink before, I might do that. where it is it gets very little airflow
Sorry, even at 0% PWM its still audible. virtually silent is NOT completely silent, and for the price its not that brilliant. Could bee that i have gotten one thats extra loud.
I can't hear mine over the fans. 8 fans usually running pretty fast and I don't have the side panel on most of the time
I can't hear my 35x with no fans running. If I put my ear against it while running I hear a slight hum.
