How much CPU power is needed to support a GPU folding?
newtekie1
Semi-Retired Folder
28,473 (4.00/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I'm putting together a Athlon 200GE data storage system, and I thought I might throw in an extra GPU I've got laying around to fold on. But will a 200GE hold back a 1080Ti? Anyone know or should I just try it?
Give it a try. My results from four different GPUs (970, 1070, 1070Ti and 2070) and two different systems (3.8 MHz i7 970 and 4.4 GHz 4790) are not conclusive. PCEi bandwidth plays in too. Sure a faster CPU (with two spare threads) is better but my 2070 doesn't take a hit on 11418s, the others do.
Got a new rig in the pipeline, mostly for WCG, but a folding 970 will be replaced by a 2070. In the same reshuffling I will run two identical rigs (2700x/GTX 970/Linux) folding on the one, not the other. There is an interesting experiment. I know already that a stock 970 under Linux gives 300-330K, its the WGC numbers that changes. Sorry for hijacking your thread :)
The Athlon 200GE runs at 3.2 GHz, so I would expect it will do just fine. Just watch the GPU utilization to see if it's holding it back.
So, nope, yep.:laugh:
CPU power doesn't really matter so long as each gpu in the system has at least one core allocated to it.
My FX 8320 fed my Vega64 Liquid just fine.. Only used 7-9% CPU on a single thread. That 200GE should be able to feed 2 GPUs just fine.
You will see a slightly faster PPD though with the 200GE over say an FX8320 as IPC is far superior with the 200GE.
I know I crunch WCG whilst I run the FAH at the same time, seems to do just fine :)
