How tight does the compression ring need to be?
452 (0.15/day)
System Name Core p90
Processor I7 9700k
Motherboard ASRock Z390 Phantom Gaming 4
Cooling Ek supremacy evo cpu block/nexxxos ut60 rad 480mm/D5 vario pump 310mm reservoir combo.
Memory Trident gskill 4x8gb 3000mhz (temporarily running 2x 32gb ddr4 corsair vengeance 3600mhz)
Video Card(s) Nvidia Founders edition rtx 3080 10gb
Storage M.2 Intel 660p 1024gb, 4tb 7200 rpm black Western Digital hdd
Display(s) Acer x34 predator 3440x1440p 120hz g-sync ultrawide 21:9 monitor
Case Thermaltake Core P90 tempered glass edition
Audio Device(s) On board
Power Supply Thermaltake smart m1200w
Mouse Razer Basilisk v3
Keyboard Logitech G910
Software Windows 10 64bit
ZMT 10/16MM black soft tube and
Barrow 10/16mm barb compression fitting. See picture.
I cannot get it further down the thread than this by hand. Tried to dip the compression ring in distiller water with a drop of soap detergent. Doesn't help much. I could try using my heat gun a bit in the tubing.
That being said, it feels tight enough to seal any leak but what do you veterans say?
I'm used to hard Tubing, this is my first go around with soft tubing
In the photo I took a compression fitting and screwed it as far as I could without using a tube to givda visual comparison between the two ✌️
Snug is all it needs. It wouldn't be able to go down that far anyway with the fitting installed in a block.
