how to change face in picture?
654 (0.10/day)
India
System Name HP envy 17 3090nr
Processor Intel core i7-2670QM 2.2ghz
Memory 8gb
Storage 1TB
Software Genuine Windows 7 Home Premium
Benchmark Scores Windows experience index 6.9
Above is the example...my friend did that..now i'm not able to contact him..
I want to do similar thing in another photo..replacing face...how can i do that?
example..i want to replace my face in following picture and also replace text House with my name..
can anyone help with that?
12,176 (1.71/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
mean? Software gimp?
Is it simple/easy?
Simple and easy is relative, it depends on how quickly you're willing or capable of learning. It takes patience, but tech requirements are pretty low. Like photoshop though, there are plenty of things that are less "simple and easy" inside GIMP.
654 (0.10/day)
India
Memory 8gb
Storage 1TB
i've downloaded gimp software..now can anyone teach/explain me how to do it?
654 (0.10/day)
India
Memory 8gb
Storage 1TB
4,876 (0.78/day)
Joplin, Mo
System Name Ultrabeast GX2
Processor Intel Core 2 Duo E8500 @ 4.0GHZ 24/7
Motherboard Gigabit P35-DS3L
Cooling Rosewill RX24, Dual Slot Vid, Fan control
Memory 2x1gb 1066mhz@850MHZ DDR2
Video Card(s) 9800GX2 @ 690/1040
Storage 750/250/250/200 all WD 7200
Display(s) 24" DCLCD 2ms 1200p
Case Apevia
Audio Device(s) 7.1 Digital on-board, 5.1 digital hooked up
Power Supply 700W RAIDMAXXX SLI
Software winXP Pro
Benchmark Scores 17749 3DM06
Doing it right is actually going to require more advanced skills, unless there is a plugin that does it for you.
I suggest instead of wasting time learning it, to give the guys in the photoshop clubhouse the job.
