How to clear S.M.A.R.T data
2,706 (0.41/day)
Oulu, Finland
System Name Enslaver :)
Processor Ryzen 7 7800X3D
Motherboard ASUS TUF Gaming B650-Plus
Cooling CPU: Noctua D15 G2, Case: 2 front in, 1 rear out
Memory 2x16GB Kingston Fury Beast RGB 6000MHz
Video Card(s) ASUS TUF RTX 4070Ti OC
Storage Samsung Evo Plus 1TB NVMe , internal WD Red 4TB for storage, WD Book 8TB
Display(s) LG CX OLED 65"
Case Lian Li LANCOOL II Mesh C Performance
Audio Device(s) HDMI audio powering Dolby Digital audio on 5.1 Z960 speaker system
Mouse Logitech G700
Keyboard ASUS Strix Tactic Pro
Software Windows 11 Pro x64
Hi!
I got a HDD with bad sectors on it from a friend and was able to repair the drive with hdd-regenerator.
Because the drive was in use as it had bad sectors the S.M.A.R.T data got messed up.
How i can reset it or clear it - so that the windows vista installation or startup screen doesnt complain about the drive beeing faulty when smart is enabled in the bios.
Thanks..
ktr
7,404 (1.06/day)
Or you can just disable S.M.A.R.T. in the bios.
Graogrim
308 (0.05/day)
East Coast US
System Name Paradigm
Processor i5 3570k
Motherboard MSI Z77A-G43
Cooling OEM
Memory 8 GB Corsair Vengeance DDR3 2133
Video Card(s) EVGA GeForce GTX 670 2 GB
Storage 128 MB Corsair M4 SSD + 1 TB WD Caviar Black
Display(s) Samsung 24"
Case Rosewill Challenger USB 3
Audio Device(s) Soundblaster X-Fi Titanium HD
Power Supply Corsair GS 800
Software Windows 7 64 bit
That data scrubber simply "superdeletes" data by overwriting trashed files to prevent casual data recovery. It won't actually reset SMART information. To be honest I don't know of a way to reset SMART data. It's something that the hard drive maintains internally, and in any event it would be a counterproductive thing to do.
Hard drives ship with spare space for error recovery purposes. Although the process can occur automatically, what recovery tools do is help cue the hard drive to "remap" physically bad sectors to this spare space. Once remapped, when a read or write would otherwise occur to a bad sector, the drive instead automatically and transparently diverts the access to the reserved area, thus hiding the error.
Here's the kicker: this doesn't fix the original problem. The error is still there, the drive is just working around it. And statistically speaking, the hard drive now has a much shorter life expectancy and probably shouldn't be trusted to hold any crucial information.
That's what this SMART error is telling you. If you want to ignore it, disable SMART in the BIOS. But your best bet is to just get a new hard drive. You're likely in for a lot of hair pulling frustration if you don't.
