- Jun 14, 2021
- 2,487 (1.76/day)
- UK
I have just bought these
upHere 120mm 3PIN Dual halo white LED PC Case Fan,High performance Silent Fan for PC cooling,DP12BE3-3 I did order blue ones but they sent my white ones?
Processor | faster at instructions than yours |
Motherboard | more nurturing than yours |
Cooling | frostier than yours |
Memory | superior scheduling & haphazardly entry than yours |
Video Card(s) | better rasterization than yours |
Storage | more ample than yours |
Display(s) | increased pixels than yours |
Case | fancier than yours |
Audio Device(s) | further audible than yours |
Power Supply | additional amps x volts than yours |
Mouse | without as much gnawing as yours |
Keyboard | less clicky than yours |
VR HMD | not as odd looking as yours |
Software | extra mushier than yours |
Benchmark Scores | up yours |
Thanks for that dirtyferreteasiest way if you are going to run them at max RPM is to daisy chain the molex connectors otherwise if you want to control RPM they need to be connected to your mobo directly or through a splitter or get a fan hub.
the pads are supposed to help prevent vibration noise although you can debate how well they work
That is correct ,i wish they had sent me the Blue ones i ordedif I'm looking at the right fans, they are just LED fans and not RGB
if they are RGB fans you would need to connect the RGB connectors but all i see from your image is the 3-pin power and molex
System Name | Ghetto Rigs z490|x99|Acer 17 Nitro 7840hs/ 5600c40-2x16/ 4060/ 1tb acer stock m.2/ 4tb sn850x |
Processor | 10900k w/Optimus Foundation | 5930k w/Black Noctua D15 |
Motherboard | z490 Maximus XII Apex | x99 Sabertooth |
Cooling | oCool D5 res-combo/280 GTX/ Optimus Foundation/ gpu water block | Blk D15 |
Memory | Trident-Z Royal 4000c16 2x16gb | Trident-Z 3200c14 4x8gb |
Video Card(s) | Titan Xp-water | evga 980ti gaming-w/ air |
Storage | 970evo+500gb & sn850x 4tb | 860 pro 256gb | Acer m.2 1tb/ sn850x 4tb| Many2.5" sata's ssd 3.5hdd's |
Display(s) | 1-AOC G2460PG 24"G-Sync 144Hz/ 2nd 1-ASUS VG248QE 24"/ 3rd LG 43" series |
Case | D450 | Cherry Entertainment center on Test bench |
Audio Device(s) | Built in Realtek x2 with 2-Insignia 2.0 sound bars & 1-LG sound bar |
Power Supply | EVGA 1000P2 with APC AX1500 | 850P2 with CyberPower-GX1325U |
Mouse | Redragon 901 Perdition x3 |
Keyboard | G710+x3 |
Software | Win-7 pro x3 and win-10 & 11pro x3 |
Benchmark Scores | Are in the benchmark section |
it's not the only option, in fact if it was my PC i would use the 3-pin to the mobo or splitter for two of the fans if needed. Molex is an an easy option if you don't mind full RPM and have the molex connector from your PSU all set to go and you simply daisy chain the 3 fans.Molex is the only option to connect them.It is not worth getting a hub then.
it looks as if those strips come off like stickers and go on the screw stands but without having fans and pads in hand and going by a pic it's hard to tellWhere would i put thouse strips i showed you on the photo?
System Name | Gamer |
Processor | Ryzen 7 5800X3D |
Motherboard | Gigabyte X570 Aorus Elite WIFI |
Cooling | Apogee XL, MCR360, MCP655, Micro-rez |
Memory | 2x16GB G.Skill DDR4-3600 CL16 |
Video Card(s) | RX 9070 XT Hellstone OC |
Storage | WD SN850 1TB & SN750 1TB |
Display(s) | LG 32GK650F-B 32" 1440p 144Hz |
Case | Rocketfish (Lian Li) e-ATX (2006) |
Audio Device(s) | Harman Kardon HK695 2.1 |
Power Supply | Seasonic Focus GX-850 |
Mouse | HP HDX wired |
Keyboard | Logitech G110 wired |
VR HMD | HP WMR 1440^2 |
Software | Win10 Pro 64bit |
My picture is ok.Hi,
Not sure how you go from a crappy picture in the op to a youtube video, oops wait that's what this thread is about youtube clicks lol
Read the instructions dude.
Thanks for that info
No, I have,t, but here is a video of the white ones the guy has here. the ones I was sent. After watching the second video to put three more fans in the case I might just put two of them in there.Have you plugged any of them in yet? So they are white LED? If you haven't powered them up yet, the white blade may glow blue.
Is this in the right postion ,the screws were hard to get in.I will just put one in the bottom and leave the front one.Have you plugged any of them in yet? So they are white LED? If you haven't powered them up yet, the white blade may glow blue.
