How to disable second display for 3d applications?
AMDCam
1,085 (0.15/day)
Colorado, United States
Processor AMD Opteron 148 at (hope) 3.0ghz
Motherboard MSI K8N Neo2 Platinum with Nforce 3 Ultra
Cooling XP-90C (CPU), A400 (Graphics), 8 case fans, 92mm Tornado
Memory 2gb OCZ Gold DDR500 dual-channel
Video Card(s) Leadtek 6800GT near UEE speed (448core/1.18memory)
Storage 2x 80gb WD 7,200rpm 8mb cache Caviar SATA 150 in RAID 0
Display(s) (2 soon) Samsung Syncmaster 172N 17" LCD
Case Atrix black case with A LOT of mods
Audio Device(s) Motherboard
Power Supply Aspire 520w tri-fan blue LEDs
Software Windows XP Home, Office 2003 Professional Edition
Hey, I'm getting tired of having to manually disable and change contrast, color, icons and backgrounds, etc. on my secondary display when I play games because when it's enabled games don't play. Is there an option in Nview where it will sense when there's a 3d/fullscreen app playing and disable the second monitor if the app doesn't need to use it? Thanks
i think you must deactivate dual view in the drivers and use single which is your monitor.
But how do I do that? And I don't want it permanently disabled, only when I play games.
