How to display clock in AM & PM format?
2,706 (0.41/day)
Oulu, Finland
System Name Enslaver :)
Processor Ryzen 7 7800X3D
Motherboard ASUS TUF Gaming B650-Plus
Cooling CPU: Noctua D15 G2, Case: 2 front in, 1 rear out
Memory 2x16GB Kingston Fury Beast RGB 6000MHz
Video Card(s) ASUS TUF RTX 4070Ti OC
Storage Samsung Evo Plus 1TB NVMe , internal WD Red 4TB for storage, WD Book 8TB
Display(s) LG CX OLED 65"
Case Lian Li LANCOOL II Mesh C Performance
Audio Device(s) HDMI audio powering Dolby Digital audio on 5.1 Z960 speaker system
Mouse Logitech G700
Keyboard ASUS Strix Tactic Pro
Software Windows 11 Pro x64
Hi!
I want to display my 2 additional clocks for east-cost and west-cost time in Win7 in AM and PM time format but everything I tried in the "Region and Language" window doesnt help.
I could live with my local clock being AM PM too.
I installed Win7 with Location Finland and finnish keyboard etc so I tried to change location to US but didnt help.
Is it even possible to tune the clocks to be displayed the way I want?
I do not really need the change but it would help a little in chats to the US and to make AM PM thinking easier for an european.
Lauri
Click on Change Date and Time Settings...
Click on Change Date and Time...
Click on Change Calender Settings
Click on the Time tab
Set the Short time to h:mm tt
Set the Long time to h:mm:ss tt
The last two settings are case sensitive. If you use an upper case H, then you get the 24H clock style, a lower case h gets the 12H format.
Alternately you should be able to set the same settings directly in the Format tab of Language and Region settings.
THX the help! I even found an easy way out and a funny bug in Win7 thru your post.
The small h was entirely missing so I changed the Format setting in Region and Language to English (United States) to see if it helps.
It did change the whole tab to US format itself when I pressed Apply so the system clock too :)
The bug I found is that Win7 tries to tell me that the First day of the week is Sunday in the US!?
Ok I know that you over there dont start working on Sunday, so I wonder which religion M$ is claiming most US ppl have - just LOLed a little at M$ again.
