How to enable GPU acceleration in Adobe Premiere Elements
Regeneration
NGOHQ.COM
3,151 (0.44/day)
What do you know! There is video editing software in 2022 that doesn't support GPU acceleration out-of-the-box. And it's Adobe Premiere Elements, none of the less. It seems that just a few GPUs are supported, while many others display "Detected Graphic Processor(GPU) is unsupported" message.
This is how you can get it fixed:
Navigate to C:\ProgramData\Adobe\Premiere Elements\20.0\Online\Hw Acc Render\All_Lang\HW\Files\
Edit allowlisted_cards.txt
Add your GPU to the list, if it's Nvidia, it should be in the following format:
NVIDIA#GeForce RTX 3090#
For AMD GPUs, you need to add in the GFXID format, you can use the TPU database, for instance, RX 6600 XT would be like this:
AMD#gfx1032#
For Intel GPUs it should be:
Intel#Intel(R) UHD Graphics 617#
Now you can enable GPU acceleration from the application general settings.
