How to fix performance issue
J_Soft
1 (0.00/day)
I'm having serious FPS drops (lags) and stuttering in video games, making it unbearable to play. Despite having high-end components, my gaming experience is far from smooth and comfortable, and I'm at a loss for what to do next. Here's a detailed breakdown of the issue:​
System Specifications:​
The Issue:​
  1. (Severe) FPS Drops:
    • My games (like Fn) can reach very high FPS (maybe up to +300), but they frequently drop to extremely low levels (as low as 4 FPS). This fluctuation is drastic and happens unpredictably, making it impossible to enjoy a game.
    • For example, in game, I can have a FPS limit of only 144, but it can suddenly drop to single digits.
  2. Stuttering & Delays:
    • The game stutters and freezes, especially noticeable when there are rapid actions, such as shooting. The screen and audio both freeze for about 1-2.4 seconds, which is incredibly driving me mad.
What I've Tried:​
  • Reinstalling Drivers: I have reinstalled the latest drivers for my GPU, but the problem persists.
  • DirectX 12: I’m using DirectX 12 in game.
  • Settings Adjustments: I've adjusted various in-game settings and tried the lowest configurations, but doesn't resolve the issue.
  • Temperature Checks: All components are running within normal temperature ranges.
Details:​
  • The issue occurs regardless of the game's graphics settings or resolution.
  • I have no background applications consuming significant resources during gameplay.
  • All components are relatively new and should be capable of handling the games I play.
Possible Causes?​
  • I don'teven know at all, man. I mean, I'm uncertain whether this is a software issue, a gaming problem, or something else entirely. Could it be related to the PC or a specific thing I'm overlooking?
Need your help:​
  • Has anyone else heard of similar issues with sudden FPS drops and stuttering despite having pretty good hardware?
  • What do I need to do to fix the problem?
BIOS version/date: American Megatrends Inc. 2407, 07/01/2020
Update your bios to version 4403 or later:
ROG STRIX X570-F GAMING BIOS 4403
Version 4403 20.51MB 2022/05/31
1. Update AMD AM4 AGESA V2 PI 1.2.0.7.
2. Fix AMD fTPM issue causes random stuttering. <<<
When did you build the system and when did you start having problems, was it after a software update?
What storage drives are you running? Software-OS?
What monitor, mouse/controller are you running?
Where did you buy the gpu from?
How old is the PSU?
Corsair Vengeance has been spotty at best on AM4.
Get hwinfo64, run it with sensors, run a normal game session, close game and provide a screenshot of the psu voltages, system temperatures, cpu and ram performance numbers please.
Also get latency monitor and provide numbers from that too.
TPM has been known to cause problems
BIOS log is sooooooooooooooo huge:
Update AGESA version to ComboV2PI 1.2.0.Ca.
Fix AMD processor vulnerabilities security.
Update AGESA version to ComboV2PI 1.2.0.B
Update AMD 5000/3000 Series CPU fTPM version, please back up Bitlocker recovery key before updating this version BIOS
Update AGESA version to ComboV2PI 1.2.0.A
Mitigate the AMD potential security vulnerabilities for AMD Athlon™ processors and Ryzen™ processors
Improve system stability
Update AGESA version to ComboV2PI 1208
Improve system compatibility,
Improve system performance and stability
Improve system performance for AMD Ryzen 7 5800X3D
Update AMD AM4 AGESA V2 PI 1.2.0.3 Patch C
Support Windows 11 by default, no settings changes required in the UEFI BIOS.
Update AMD AM4 AGESA V2 PI 1.2.0.3 Patch A
Improved system compatibility
Update AMD AM4 AGESA V2 PI 1.2.0.1 Patch A
Fix USB connectivity issue
Support Smart Access Memory for Ryzen 3000 Series Processors
Fix the L3 cache performance in AIDA64
Improved system performance
Improved memory performance
Update AMD AM4 AGESA V2 PI 1.2.0.0
Update AMD RAID UEFI driver
New CPU support
Add a ReSize BAR shortcut for AMD SAM support
Updated AMD AM4 AGESA V2 PI 1.1.0.0 Patch B
Improved DRAM compatibility
Improve graphics card compatibility"
Improve Fan control function
Improve DRAM stability
Update AM4 AGESA combo V2 PI 1.0.8.0
Improve DRAM performance
