How to flash Powercolor Red Devil Vbios into XFX RX 590 Fatboy Core Edition 8GB 1545MHz
wbx
9 (0.01/day)
Hello, I have recently bought a used XFX AMD Radeon™ RX 590 Fatboy Core Edition 8GB 1545MHz with the purpose to use it under windows but also under macos. I have then read that the XFX RX 590 original firmware makes it non compatible with the recent macos versions like Mojave and Catalina or Big Sur.
A "simple" way to re-gain macos compatibility seems to flash the board with the Powercolor Red Devil Vbios. I have seen this video
that shows how easy seems to flash the vbios without risks but saving before the original bios.
I have tried to follow the video guideline to do my job but suddenly faced big difficulties:
I have saved the XFX RX 590 Fatboy Core Edition 8GB 1545MHz Vbios with the command
amdvbflash -s 0 BIOS-backup.rom
and surprisingly the saved file is long as the 2 vbios dimensions or 512 K.
Then I have put the board switch toward the power connectors and saved the vbios from GPU-Z application. This time I have saved a file 256 K long. I have then tried to upload this file to Techpowerup data base but the answer of the procedure have been "we already know this file as 219267.rom" and be careful to flash it ...
Next I have put the board switch toward the external video connectors and again saved the vbios from GPU-Z application again 256 K long. I have then tried to upload this file to Techpowerup data base but the answer of the procedure have been "we already know this file as 223160.rom" and be careful to flash it ...
Finally, I have tried to flash the Powercolor Red Devil Vbios downloaded from Techpowerup data base: Powercolor.RX590.8192.181106.rom with the command
amdvbflash -p 0 BIOS.rom
and I have received an id mismatch error.
Then I have tried to flash the board bios from its backup receiving the answer "already loaded vbios" or similar... This test to see the amdvbflash application at work but nothing seen.
Now I am very disappointed because while I don't want to brick my valuable board payed a lot, I don't know how to safely test the powercolor RX 590 Firmware that other people say solved every compatibility problem with macos. By the way the XFX RX 580 is fully macos compatible out of box ... I would flash its vbios but the Powercolor one seems to be more compatible with my XFX board model...
Please help to clarify the 512 -256 K dimensions doubts of saved vbios as well as the safety of testing the Powercolor or other compatible firmwares according to the above mentioned video.
Thanks a lot.
Walter
578 (0.32/day)
System Name Mini efficient rig.
Processor R9 3900, @4ghz -0.05v offset. 110W peak.
Motherboard Gigabyte B450M DS3H, bios f41 pcie 4.0 unlocked.
Cooling some server blower @1500rpm
Memory 2x16GB oem Samsung D-Die. 3200MHz
Video Card(s) RX 6600 Pulse w/conductonaut @65C hotspot
Storage 1x 128gb nvme Samsung 950 Pro - 4x 1tb sata Hitachi 2.5" hdds
Display(s) Samsung C24RG50FQI
Case Jonsbo C2 (almost itx sized)
Audio Device(s) integrated Realtek crap
Power Supply Seasonic SSR-750FX
Keyboard Redragon K539 brown switches
Software Windows 7 Ultimate SP1 + Windows 10 21H2 LTSC (patched).
Benchmark Scores Cinebench: R15 3050 pts, R20 7000 pts, R23 17800 pts, r2024 1050 pts.
The bios firmware contains, among other things, the profile for vrm. So if the cards are too different then by flashing the other cards' bios can potentially damage the card. Prior to anything else, test the card as it is, to see if any tinkering is actually necessary. Also, are you putting it into a real Mac Pro or just prepping ur hackintosh setup? because afaik vbios mostly has to do with the mobo compatibility, and if u are running hackintosh then the mobo is not apple-specific.
wbx
9 (0.01/day)
I have put the card in an HP Z 600 workstation running Windows 11 and also macos Yosemite without any changes but more recent macos versions do not work.
The cards are very similar. Look at this:
and this where it says "Had to flash the vbios on my GPU because XFX are not supported so had to change it to a RX 590 Powercolor and worked straight after :)"
https://www.reddit.com/r/hackintosh/comments/f9rfwe
then also look at
where it says
Polaris 10 and 20 series
#Highest Supported OS: Current/Monterey (12)​
#Initial Supported OS: Sierra (10.12)​
Regarding Polaris, basically every model of card is supported as long as it’s running either a Polaris or Baffin core(lower end cards like the RX550 run a Lexa core meaning no support in macOS).
The only brand of GPU you should avoid with the Polaris series would be XFX, PowerColour, HIS and VisionTek as many users have had issues with these cards with viewing Clover and macOS booting but other users have found fixes/workarounds(though nothing consistent). This seems to be caused by having an odd VBIOS that doesn't communicate well with macOS and the only real solution is flashing another VBIOS which is not ideal for most users.
Supported cards:
400 Series:
  • RX 480
  • RX 470D
  • RX 470
  • RX 460
500 Series:
  • RX 590
My question is how to do without bricking the board...
Thanks.
Walter
1,891 (1.29/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Hello.
IF after all the procedure you will end up in bricking the video card ...then you will unbrick it and you will start all over again.
I mean it.
I have XFX 580 8gb BIOS in some Sapphire Pulse 8 gb cards (mining purposes ofc)
If you fail , then you could follow the unbricking procedure over and over again until your desired outcome.
wbx
9 (0.01/day)
Thank you impero for your suggestion, can you please answer to the following specific questions ?
1- Why saving vbios with the command amdvbflash -s 0 BIOS-backup.rom I obtain a file that is long 512 K (like 2 vbios dimensions) while when I save it through the GPU-Z utility the file has only 256 K length ?
2- When I flash the firmware to adapter 0 the only way to distinguish between the 2 vbios memories is the position of the (vbios) mini switch ?
3- When I flash the Powercolor Firmware I have to consider only one vbios: in which position of the switch I have to flash it or it is indifferent ?
Thank you.
Walter
1,891 (1.29/day)
Romania
Hello
I can't answer to the question regarding of the dimension of the file.
When you flash the ROM you must choose what version you flash in it and you choose the correspondent switch position.
I mean you must choose between silent and performance version of the BIOS. So you must flash normal BIOS file in it while the switch is positioned to silent position.
Same for performance one.
Near the power cables is performance mode, while the position farthest from the power connector cables is the quiet/stealth mode
wbx
9 (0.01/day)
Hello, i have tried to flash the Powercolor Red Devil vbios to the XFX 590 Fatboy Core Edition 8GB 1545MHz but i have had the following error:
Saving bios to BIOS_backup.rom...
AMDVBFLASH version 3.20 EXTERNAL, Copyright (c) 2021 Advanced Micro Devices, Inc.
-f option not support in external version of the tool. Please refer to tool help for list of option supported
Old SSID: 9587
New SSID: 2391
SSID mismatched
ERROR: 0FL01
Premere un tasto per continuare . . .
Please help.
Walter
1,843 (0.59/day)
BGD
System Name Minotaur
Processor Intel I9 7940X
Motherboard Asus Strix Rog Gaming E X299
Cooling BeQuiet/ double-Fan
Memory 192Gb of RAM DDR4 2400Mhz
Video Card(s) 1)RX 6900XT BIOSTAR 16Gb***2)MATROX M9120LP
Storage 2 x ssd-Kingston 240Gb A400 + HDD 500Gb+2xSSD Kinston 480Gb+5Tb Seagate+512Gb NVME SGI
Case NZXT H5 Flow
Mouse Asus TUF-GAMING M3
VR HMD Oculus Rift DK2
Software Win 11
Benchmark Scores Fire Strike=23905,Cinebench R15=3167,Cinebench R20=7490.Passmark=30689,Geekbench4=32885
Download some older atiflash vers and use the -f(force method) I am pretty sure it will work just fine as I personally did flashed many times,RX 470,RX 480,R9 Fury,R9 380....and it works....
1,891 (1.29/day)
Romania
Hello.
Do not use 3.20 version.
From that menu you will choose version 2.93.
And you will use that version to flash your card.
Good luck
wbx
9 (0.01/day)
Thank You Impero and Zyll Goliat !! Your advices are very useful.
I change the atiflash version and try again to do the flash ...
Just done unistalling the driver of version 3.20 ...
It says:
cannot load driver
and I am stuck.
Sorry I have used to flash the same text of the saving-Vbios.bat. but the command is for flashing.
Just corrected. Now it says:
Flashing bios from BIOS.rom...
cannot load driver
44,288 (6.80/day)
Tul cards are known to be locked hard. I recall not being able to flash 1 side of a bios on a RD 5700XT but the other would flash fine. Get a SPI flasher
wbx
9 (0.01/day)
Impero told me:
"So you must flash normal BIOS file in it while the switch is positioned to silent position.
Near the power cables is performance mode, while the position farthest from the power connector cables is the quiet/stealth mode"
The switch was positioned in silent position during last flashing attempt. Which position is "protected" ?
I was not aware of the command:
Amdvbflash.exe -unlockrom 0
I try.
1,891 (1.29/day)
Romania
Hello
In my experience i did not encountered RX5xx series that does have a protection at the hardware level (the switch).
The switch is used to change the version of the BIOS you use.(performance or silent)
In fact the BIOS files are write protected at a software level, for unlocking ROM there is a specific command in amdvbflash.exe which do exactly this.
Last Edit : after i searched on the web i found an answer from Gigabyte technical crew to a customer where they answered the following :
"It is a Dual BIOS switch which can be toggled between a protected BIOS and an unlocked BIOS to be used to flash that latest BIOS mod. Both BIOS have the same frequency."
So the performance BIOS can be flashed after what they say.
On Sapphire , on the other hand the switch do what i am used to : switching from performance to silent:
"Use the physical switch on the card to move between performance mode or silent mode to choose the best BIOS experience for your gaming with the Dual BIOS feature. With the TriXX Software BIOS Switch position, gamers can easily switch from performance mode to silent mode and back using our TriXX software for a quick and convenient way toalternate between the dual BIOS modes.
For quieter operation, the Secondary, or Silent setting reduces clock targets and raises target temperatures."
So it appears that on some producers it will write protect the file when the switch it is in one position.
wbx
9 (0.01/day)
Hey guys successfully flashed Powercolor vbios now working perfectly.... :):):):)
hereafter the procedure followed:
Procedure to flash Powercolor Vbios:
install ver 3.2 e 2.9
install driver flash ver. 3.2
from ver 3.2 issue command
amdvbflash.exe -unlockrom 0
switch to ver 2.9
save old bios with GPU-Z (256K wide)
save old bios with the following script (512K wide)
cd C:\Users\walte\Desktop\XFX-RX590-Flash\atiflash_293
@Echo off
cls
echo Saving bios to BIOS_backup.rom...
echo.
amdvbflash -s 0 BIOS_backup.rom
echo.
pause
download Powercolor Vbios 256K wide (in my case was Powercolor.RX590.8192.181106.rom)
rename it as BIOS.rom and put it in the atiflash 2.9.3 directory
flash with the commands (inside a flash.bat file:
@Echo off
cls
echo Flashing bios from BIOS.rom...
echo.
amdvbflash -f -p 0 BIOS.rom
echo.
pause
N.B. the board vbios switch is toward power connwctors
finally (optional)
amdvbflash.exe -lockrom 0
End of procedure
44,288 (6.80/day)
3.2 changed syntax, but 2.93 is a little easier to use
1,891 (1.29/day)
Romania
Hey, nice to see that you made it.
Have a nice day mate!
wbx
9 (0.01/day)
Thank you all for your help that made possible my success in Flashing the XFX AMD Radeon™ RX 590 Fatboy Core Edition 8GB 1545MHz with the Powercolor firmware making this way the board compatible with macos Mojave and also more recent macos versions.
What I have learned is that few little advices and knowledge from many people lead to understand and finally do the job... :):):)
Mr.CorTex
1 (0.00/day)
Hey wbx, Thank you very much for sharing this awesome guide :) thankfully I found this post and you help me a lot. I was in the same spot with the XFX RX 590 on macOS Big Sur and now Monterey, both OS detected the card but won't let me connect through. With the PowerColor vbios it worked like a charm on my Intel NUC10 with external graphics tower connected via Thunderbolt 3.
1,891 (1.29/day)
Romania
Nice to see that our work gives results.
Cheers mate
