how to ground myself in a REALLY static heavy enviroment?
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
Hello TPU,
As the title says, Im forced into a corner here. I have been in the hospital for over a week, and need to build My nephews PC before Xmas. I have everything needed, component-wise, but in my new place, 95% of the House is carpet, and Base board electric heat, which as Most of all of us know,='s Extreme static electricity.
To be totally honest, Ive never given a second thought to static , but in this new place, every time i touch a light switch, a family member, or any other thing, i discharge static, and Im concerned about building a new PC with all the damn shock potential, since i dont want to damage anything. Needless to say, ive never bought, or even thought about buying a static strap, but Im sadly in a position that i feel i might need one now.
what can i do to get around this issue? I know i can touch something to ground myself before handling parts, but i was thinking of something i can do beyond that. i.e a makeshift static strap etc...
thanks in advance.
& Merry Christmas:toast:
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Tape a bare wire to your skin. Connect the other end to the screw that holds down the cover plate for an outlet or light switch. Of course, you have to be comfortable that the house is wired correctly....
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Get a strap but realize it needs to go to a natural ground. ie faucet or pipe. Or make one.
Some will tell you to plug the unit on and just ground to the case but that is not my suggestion. Never work on something that is plugged in
I agree with ^ if your house is wired correctly the screw on the outlet should be grounded
silentbogo
5,649 (1.35/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
$1 strap, and clip it to the nearest heating/water pipe.
Alternatively - build it in the kitchen or bathroom. Pretty sure there is no static there.
You may even discharge yourself by touching the nearest water pipe or a faucet.
7,607 (1.44/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
18,584 (2.64/day)
System Name AlderLake
Long time ago I worked at Xerox making copiers, we had to wear this:
6,881 (1.42/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
Build it in patio/porch if possible. Might be cold outside where you are.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
yeah VERY cold. im in massachusetts. + its raining. It looks like im either going to need an alternate site to build in, (mother in laws house) or just do it the old fashion, ground every time before handling method.....Not certain of the wiring in this place....thanks all.
4,994 (0.69/day)
South of England
System Name Box of Distraction
Processor Ryzen 7 1800X
Motherboard Crosshair VI Hero
Cooling Custom watercooling
Memory G.Skill TridentZ 2x8GB @ 3466MHz CL14 1T
Video Card(s) EVGA 1080Ti FE. WC'd & TDP limit increased to 360W.
Storage Samsung 960 Evo 500GB & WD Black 2TB storage drive.
Display(s) Asus ROG Swift PG278QR 27" 1440P 165hz Gsync
Case Phanteks Enthoo Pro M
Audio Device(s) Phillips Fidelio X2 headphones / basic Bose speakers
Power Supply EVGA Supernova 750W G3
Keyboard Cherry MX Board 6.0 (mx red switches)
Software Win 10 & Linux Mint
Benchmark Scores https://hwbot.org/user/infrared
I usually put the PSU in the case first, then remove fuse from plug, plug it into psu so the whole case is now grounded. Then before you pick up anything, just touch a bit of exposed metal on the case to discharge yourself :) It's probably not as good as having a wrist-strap and antistatic mat to work on, but it's better than nothing.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
antistatic mat
are those just rubber or something?? i might be able to use that method, if i have something in my storage unit.
Edit
I know I have a bunch of vinyl composite tiles, a.k.a. VCT. I bet they would work ....that's what my old houses kitchen was floored with & I never had static issues there
4,994 (0.69/day)
South of England
I think they're just slightly conductive to prevent a charge building up, not normal rubber unfortunately. >This kinda thing<. I guess it's not really helpful showing you that the day before xmas tho.
Moisture helps static dissipate, maybe working on a slightly damp towel or something? Weird suggestion, but if static in your home is as big a problem as you say it might be worth doing. :oops:
19,379 (3.46/day)
Just don't shuffle across the floor like an old man that can't lift his feet and you will be fine.
If you insist, simply touch the case before working on it to normalize the electric potential. Or, as someone else said, put the psu in and plug it in... done. Grounded. It's PLENTY safe to work on it plugged in.
For the record, I have never killed anything via static electricity. Never wore a strap, never will.
7,607 (1.44/day)
Rīga, Latvia
Software FEDORA 41
13,942 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I disagree with this completely. We are not talking about getting zapped from applied AC power, but preventing a static discharge from our bodies from destroying ESD (electro-static discharge) sensitive devices like CPUs, GPUs, memory modules, motherboards, etc.
To prevent a static discharge, the goal is to put you and your computer "at the same potential". Voltage will only jump (arc) when two conditions are met. (1) The potential must be large enough to jump (arc across) the gap, AND (that's "and", not "or") (2) there must be a difference in potential. That is, the two sides of the gap must be at different voltage levels.
These two conditions are easily eliminated simply by you touching the bare metal of the case. That puts you and the case at the same potential - therefore no arcing.
Grounding to Earth ground can actually be more problematic (unless doing maintenance on "high" voltages) since electricity always tries to seek Earth ground. If you are not digging around inside the PSU, you are only dealing with low voltage DC.
Remember, airplanes, cars, etc. work just fine (and safely) and static free without being grounded to "Earth" ground. So you want a "common" and "floating" ground between you and your case and that will discharge any static in your body, and prevent the build up of more static. Keeping one hand touching bare metal works.
A wrist band is typically good enough but they come with caveats too. They need to be snug and your wrist needs to be clean. But more importantly, the bands need to be clean too. Overtime, grime and skin scum causes resistance - a bad thing. Some motherboards come with cheap, disposable wrist bands. IMO, they are for one time use.
infrared has the right idea about moisture. Get a spray bottle of clean water and lightly misting the carpet will greatly reduce static and help prevent the build up of static (at least while still damp). You can also mix in a teaspoon or so of fabric software for better static suppression.
AsRock
TPU addict
19,250 (2.95/day)
UK\USA
Cooling D15
Hello TPU,
thanks in advance.
OOh i feel your pain, cat likes it lmao. How ever the wife don't and i hate it when shopping any thing metal in the shop including tinned stuff ZAP! to the point others actually hear it.
Still today i am sure i killed a USB port some years back, some say it's not possible but it is. Reason it's never happened again is that i always earth on a PC case ( or Hifi gear ) before building or changing any thing, never had the issue since, well except in the shops lmao, ooh and do i get funny looks.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
Have a girl near you.
That normally creates more ... static.
fabric software
Geek slip?
Water pipes used to be considered a good ground and were actually used as such. Now, with all of the plastic piping, their use as a ground is no longer allowed. My house originally used the water pipe, but when I did some electrical work a few years back, I was required to drive 2 - 8ft copper covered rods into the ground and connect my ground to them.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Geek slip?
That's a good point I knew about that but I hadn't thought of it to be completely honest.
I Have to imagine you can use the old telephone lines. Everyone seems to have them ,even in newer houses there seems to be a plug on every floor for the old-style phone lines. I've even seen the power company use the old nynex grounds because they're so good .... in my old house it was like a 2 foot steel pole straight into the ground outside underneath my meter
13,942 (2.04/day)
Nebraska, USA
Mouse Logitech M190
This is true. Note "hot" water heating pipes where NEVER allowed, though radiators were often used anyway. Only cold water were at one time used because cold water pipes entered the home from at least a couple feet underground (deeper in cold climate regions). And they were made of copper. Hot water pipes were not allowed because there was no continuity from the hot to cold side, except through water in a glass lined tank. While water does conduct, it does not conduct good enough to be used for a ground.
12,340 (2.21/day)
Oregon
I think the point of grounding on metal water lines was in case the pipe becomes energized. I know they use to require a ground within 5 ft of a house. Bill is there a difference in conductive properties of types of water, hard, soft,
13,942 (2.04/day)
Nebraska, USA
Mouse Logitech M190
I think the point of grounding on metal water lines was incase the pipe becomes energized.
Energized? Huh? No way! Why and how could copper pipes that get buried in the ground without any type of insulation (the entire length of the pipes) become energized? They wouldn't - water pipes in the home would never become energized unless someone was trying to murder you!
Cold water pipes were used because (1) plumping came to houses before electricity. (2) When electricity came to houses, it came as 2-wire (hot and common) only. But because of the impurities in water, not to mention leaks and broken solder joints and shoddy plumbing repairs, ground wires were added. Then the issue of plastic pipes made 3 wires mandatory.
Yes, but that's irrelevant to this discussion. When it comes to grounding, you want 0.00Ω resistance to ground. That can only be closely achieved with top quality conductors, like continuous solid (not stranded) copper wire.
Water will conduct enough to electrocute you, but not enough to provide a sufficient ground.
12,340 (2.21/day)
Oregon
One way it becomes Energized is if you drop your hair dryer into a sink or bath. But there are other ways
The Bonding Solution
Non-metallic pipes not only disrupt a potential electrical grounding source, they can also generate a static charge from the friction caused by liquids flowing through them. As a result, the plumbing system bonds back to the electrical system, and both are grounded through a secondary electrode. Bonding is a non-corrosive grounding wire that runs from a metal plumbing pipe back to the metal box of the home’s main electrical panel, to the wire that leads to a grounding rod outside the structure or to the grounding rod itself. Creating the bond allows a circuit that carries potentially dangerous electrical charges away from the plumbing system and to ground. (Energized)
Secondary Electrodes
A secondary electrode is a length of metal, typically 8 to 10 feet, driven into the ground. When correctly installed, only enough of the rod remains above ground for attachment to a heavy gauge wire. The other end of that wire attaches to the home’s electrical system and bonds to the plumbing system. Standard building codes accept steel conduit, steel rods and coper-clad steel as grounding electrodes. These devices are also called secondary electrodes, since some electricians still ground electrical systems to the home’s plumbing. Electrical codes require the use of a second electrode in these instances.
Tying Into Plumbing
Either grounding or bonding devices secured to plumbing must be tightly clamped to an entry pipe near the point where the pipe enters the house. A grounding wire wrapped around a pipe is not a substitute for proper clamping. Neither plumbing nor electrical systems can be bonded or grounded to anything other than a properly grounded electrode. For example, incoming natural or propane gas lines may travel the proper distance underground, but they are not acceptable for electrical grounding systems, since these lines carry combustible fuel.
2,100 (0.47/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
Lightning strike.
13,942 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Neither would "energize" the pipes. Wires in the wall that are actively carrying current in a live circuit are energized.
The point of grounding on pipes was to use the pipes of as a ground. Not to energize them. But that proved to be ineffective.
And in any case, the point of this thread is how to prevent static from the body zapping electronics. So back on topic.
