how to make custom flowchart/algorithms in ms office?
654 (0.10/day)
India
System Name HP envy 17 3090nr
Processor Intel core i7-2670QM 2.2ghz
Memory 8gb
Storage 1TB
Software Genuine Windows 7 Home Premium
Benchmark Scores Windows experience index 6.9
Hello,
i want to make flowcharts/algorithms.
which is best software to do same?
can i create flowcharts easily in ms office 2007/2010 ?
in ms office smartart option is there for same but it's not allowing to make custom flowcharts..like if i want to add one more box or delete one box, it's not possible..it's just giving readymade flowcharts and we can enter text and adjust size of readymade box only, no addition or deletion of boxes..
example of flowchart:
no one have any idea?
powerpoint or visio (separate product)
Visio is the best we use at work. In my department we have a network analysis and this is what she does all day is make progressive flow charts in visio
solution
I think what you need is a simple flowchart software solution. If your algorithm is not that long use a web based (platform independent) solution like Creately. If you are making algorithms more often I recommend you to buy a flowchart software in the market.
