How to merge partitions on external Drive
118 (0.04/day)
Chile
Processor Intel Core i7-6700K 4.0GHz Quad-Core Processor
Motherboard Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard
Cooling CRYORIG M9i 48.4 CFM CPU Cooler
Memory G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory
Video Card(s) EVGA GeForce GTX 1070 8GB FTW Gaming ACX 3.0 Video Card
Storage (SSD) PNY CS2211 480GB 2.5" Solid State Drive
Power Supply EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply
I removed an HDD from a notebook which had W8 OS so I could format it and use as back up, but I couldn't because it has 3 partitions and it wont let me format the partition in the middle and merge the rest, and if I try to extend the first one it shows an error message about dynamic disk. Do you know how to merge all partitions in this case?
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Use the DISKPART command
If you don't know how just watch a video. You can completely wipe the drive and create a new partition. Which is the best way. You don't want that boot sector remaining
Another alternative that works is to use a windows install with just that drive attached. You can remove the partitions from the custom install menu
448 (0.23/day)
Panama City Beach, Florida
System Name EventHorizon
Processor Intel® Core™ Processor i9-13900KF 8P/16 + 16E 3.00GHz [Turbo 5.7GHz] 36MB Cache LGA1700
Motherboard ASUS PRIME Z790-P
Cooling CyberpowerPC MasterLiquid Lite 240mm ARGB CPU Liquid Cooler
Memory 32GB (16GBx2) DDR5/6000MHz Dual Channel Memory (KINGSTON FURY BEAST RGB)
Video Card(s) GeForce RTX™ 4080 16GB
Storage 2TB WD BLACK SN850X (PCIe Gen4) NVMe M.2 SSD - Seq R/W: Up to 7300/6600 MB/s, Rnd R/W up to 1200/110
Display(s) LG 34''
Case CyberPowerPC HYTE Y60 Dual Chamber Mid-Tower Gaming Case w/ Panoramic View Tempered Glass + 2x120mm
Audio Device(s) SteelSeries Sonar
Power Supply High Power 1300W 80+ GOLD Full Modular w/ PCIE 12+4Pins Connector for PCIe 5.0 graphics cards
Mouse Steelseries Rival 600 wired
Keyboard Steelseries Apex 7 TKL red Switch
Software Win 11 Pro
5,680 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
Aomei partition assistant is another good one if you don't want to frig round with cmd line use of diskpart
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
You don't format a partition you format the drive which is mbr already limit is four partitions before it changes the disk to dynamic which is not good.
Free mini tool is good just click on each partition and click on delete or right click each partition and delete.
Then right click the disk format gpt or leave it as mbr then create a single partition if you wish too then apply.
Edit make sure you don't want any personal files first
If you do take ownership of the disk first and retrieve those files mini tool also shows Merge option on right click menu if that is truly your objective.
5,680 (1.02/day)
Gougeland (NZ)
that's the wrong way round you must first create a partition before you can format it whether it be MBR or GPT type partitions and then you can format them to NTFS
18,456 (2.47/day)
Since you managed to get disk management up and running already (as per your second screenshot), you can simply use that. Right click on the partitions and delete them, then create a new single partition which you can then format.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Exactly this. Just select the drive using DISKPART and run a Clean command and it will wipe the drive.
No, you format the partition. You select the partition table type when you initialize the drive, that is when you pick MBR or GPT. That isn't formatting the drive, that's just selecting the partition table type. You then create a partition and format that partition with a file system(NTFS, FAT, exFAT, EXT and so on).
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
Partitions are already ntfs there is no need to format them further
Delete and move on is the only question why not instead of merging anything.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Stop talking, you have no idea how this works.
30,519 (7.07/day)
This! It really is that simple. Any partition management utility can do so.
Incorrect. The OP does not care about the data in the partitions or they would have said so. Deleting all of the existing multiple partitions and creating one new single partition is the easiest and fastest method.
You be nice.
12,340 (2.21/day)
Oregon
People are funny about diskpart. It's not that hard to use and its a powerful command. I feel like a God when I use it Haha. No need to download anything
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
I already stated delete them or merge with free mini tool but you didn't quote that post.
14,548 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Right click and delete the first two, extend the last partition as it won't allow you to extend the first two.
118 (0.04/day)
Chile
couldn't delete the middle partition using disk management so i used cmd, then diskpart , select disk, clean all, and it worked. i selected GPT partition type and then formated the drive as usual, now disk status shows as active primary partition. Do you know the difference between Basic Data Partition and Primary partition?
Thanks amigos!
12,340 (2.21/day)
Oregon
Good job, Pri partition is for your OS, data partition for data. But it will work ether way. You can change it in the Device manager
