How to obtain vbios internals?
There is no software to provide this info. I wrote all the code myself.
Thanks,
I have a vbios file and i try to determine supported memory model. Do you know how? I tried using hex editor but i don't know where to search.
As far as I know, it's not possible to determine supported memory from the BIOS file alone. You need use GPU-Z on a card that's designed for it.
When people submit a BIOS to our collection, using GPU-Z, the memory type from the GPU-Z main window is included in the submit data, that's how the BIOS collection knows memory type.
Email me the BIOS to w1zzard@techpowerup.com, maybe it is in our collection.
I sent you an email.
Can you also check your collection for MSI R7 260X 1GD5 OC or R7 260X 1GD5 vbios?
edit:
I managed to find "H5GQ2H24AFR" string in vbios using HxD hex editor, so i guess it is supported.
