How to optimise 5700x for best performance
869 (1.15/day)
Processor Ryzen 5700x
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory TeamGroup T-Force Delta RGB 32GB 3600Mhz
Video Card(s) PowerColor Red Dragon Rx 6800
Storage Fanxiang S660 1TB, Fanxiang S500 Pro 1TB, BraveEagle 240GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply Corsair RM750x SHIFT
Currently I have set PPT: 105 TDC: 75 EDC: 110, I enabled CO -20 on all cores and a small -0.04v voltage offset, and +200mhz, currently it is cinebench r23 stable and holds 4.62-4.63GHz multicore and 4.85GHz (give or take) on single core, all while staying at 70c or lower and around 107w full package power draw running CB MT, is there anything I am missing or could change, bare in mind my goal is ultimate performance with temps in check which they are at the moments, specs.
5700x - Thermalright Peerless Assassin SE
Gigabyte b500 Aurus Elite AX V2
32GB TeamGroup RAM
PowerColor 6800
Yes that’s a very optimal config. I’ve had my 5800X setup very similar for over 3 years. It’s an aging platform that’s about as far as you can stretch it.
5700x- Ak620 dark zero air
B550 Gigabayte Aorus Ac
Team xtreem argb ddr4-3600mhz cl16
Sapphire rx7600
Seasonic m12ii 620w
All core 4.8 ghz 1.3v ile R23 score is at the bottom
