L
leidola
Hello!
I'm interested in how you read the gpu temperature in your software? Do you directly access the LM63 chip via the I2C bus or does the ATI-driver export the temperature?
There is a project called lm_sensors which does hardware monitoring for various sensor chips. They write the following about LM63:
It would be cool if you could share some knowledge
Ciao,
Olaf
[LM63] Found on some ATI graphics adapters. Temperature part is more or less compatible with the LM86, support could be added to the lm90 driver. However, we could not access the LM63 chips on these boards so far. It didn't show on any of the 4 known I2C busses of the graphics adapter. Until we know how to access it, there is no point in supporting the chip.
Ciao,
Olaf
