How to turn on MSI Afterburner min, max and avg fps ?
767 (0.27/day)
Latvia
Processor AMD Ryzen™ 7 7700
Motherboard ASRock B650 PRO RS
Cooling Thermalright Peerless Assassin 120 SE + Arctic P12
Memory XPG Lancer Blade 6000Mhz CL30 2x16GB
Video Card(s) ASUS Prime Radeon™ RX 9070 XT OC Edition
Storage Lexar NM790 2TB + Lexar NM790 2TB
Display(s) HP X34 UltraWide IPS 165Hz
Case Lian Li Lancool 207 + Arctic P12/14
Audio Device(s) Airpulse A100 + Ruark RS1
Power Supply Sharkoon Rebel P20 750W
Mouse Cooler Master MM730
Keyboard Krux Atax PRO Gateron Yellow
Hi guys!
I have a problem i can't find how to turn on min, max and avg fps in MSI Afterburner real time on screen display maybe somebody knows how to do that thing right ?
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
If you mean how to turn on the minimum or maximum recorded frames per second it's under the video capture tab in settings
You may want to go through your sensor and OSD settings and turn off a few of those uneeded osd display options.for example remove "show in OSD" for all those silly cpu Cores ,and just leave the CPU package. there's no reason to see the temperature of every core.it totally ruins the game experience to have a wall of text for the whole screen
these are the only important option to have in OSD, unless you have some specialized reason.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
r u certain thats afterburner?
im guessing who ever recorded that clip, played around with Revatuner. i see the options for min max etc ,but im not gonna take the time to figure it out.
the icon for revatuner wil be in the icon tray , it looks liek a blue screen/monitor. the window looks like this, and the setup button is on the bottom left
6,881 (1.42/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
Why dont you ask the guy you took that screen cap from on youtube ?
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
im guessing these are the options needed
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
i screwed with it in several ways, & cant get what dude wants, im starting to think this is either an older AB/RT version, or not AB/RT at all.
Does this help?
i think he's lookign for a way to display Min/Avg/Max FPS in OSD. like in ths pic in OP, but i cant get it to work on Current AB/RT version o_O i dunno, i think it isnt AB, look at how it shows gpu temp? mine doesnt say it like that, unless its modified on a .cfg level
6,881 (1.42/day)
Florida
Storage Various
It might be evga precision.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
yeah....i dont think thats AB. my AB doesnt say "GPU Temp" , im sure that can be modified, but regardless theres no setting for this in AB/RT
i made live graphs, frame time metering , and all other kinds of crap pop up on OSD, but not that Min Mx stuff
767 (0.27/day)
Latvia
Maybe it's somehow through Hardware info ? 14:17
767 (0.27/day)
Latvia
I tried it didn't work. It's possible to set only one fps counter which is min, max or avg not all tree or even two.
236 (0.05/day)
System Name Coffee Lake S
Processor i9-9900K
Motherboard MSI MEG Z390 ACE
Cooling Corsair H115i Platinum RGB
Memory Corsair Dominator Platinum RGB 32GB (2x16GB) DDR4 3466 C16
Video Card(s) EVGA RTX 2080 Ti XC2 Ultra
Storage Samsung 970 Pro M.2 512GB - Samsung 860 EVO 1TB SSD - WD Black 2TB HDD
Display(s) Dell P2715Q 27" 3840x2160 IPS @ 60Hz
Case Fractal Design Define R6
Power Supply Seasonic 860 watt Platinum
Mouse SteelSeries Rival 600
Keyboard Corsair K70 RGB MK.2
Yeah - that's not Afterburner. Not sure which one it is, maybe PrecisionX.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Fraps looks like it will do it
19,379 (3.46/day)
Fraps has osd. Works in dx11.
Have they updated it to work in dx12?
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
I have no idea, I just found similar value readings to what OP was asking for so I posted it.
I would hazard a guess that any support afterburner offers fraps also offers ,since fraps cost money and afterburners free ;)....but fraps is also dog$hit, atleast for recording gameplay it is $hit. Using fraps to record gameplay is like using a chainsaw as a shoehorn.
A
AlexUnwinder
Wrong, that's Afterburner 4.4.0 + RTSS 7.0.0 with benchmark mode enabled. You see it in OSD if you enable "Show own statistics" in RTSS and start a benchmark recording session (i.e. press "Begin recording" hotkey defined in "Benchmark" tab).
767 (0.27/day)
Latvia
Thanks man! You just made my day.
467 (0.13/day)
South Africa ,Lions Everywhere..
System Name Ground Control
Processor Intel i5 2500k 4 Ghz
Motherboard MSI P67A-GD80 B3
Cooling Cooler Master Hyper 212x
Memory 2 x 4GB DDR3 1600mhz Apacer Black Panther
Video Card(s) Msi GTX 1060 OC 3Gb
Storage 2 x 250Gb WD Blue raid 0 + 1Tb Wd Green
Display(s) Samsung BX2450 24" Led
Case GMC X7 X-Station
Power Supply HEC Raptor 500watt
Mouse Logitech G9
Software Windows 8.1
Benchmark Scores Power Level over 9000
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (1.93/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Mouse cheap
Keyboard under going restoration
467 (0.13/day)
Mouse Logitech G9
attachment doesnt work
do you use that prog?............thoughts?
Use thumbnail- attachment was same thing (edited)
Just installed it to test , as recalled it may of had those function the OP wanted
I don't use it otherwise - I use msi afterburner .Tried to use it to take screenshot of cam osb but didn't capture the osd
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
what an awful unintuitive couple of programs :kookoo:
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
so... you tested this and it works?
It does work, I didn't believe it at first, but you turn on a setting (which I've never seen for years) in Riva tuner, and then you have to go back into afterburner ,into the settings, and now there's a new tab called "benchmarking" ,with an option that you can check to accomplish this. SO unintuitive....ofc i and 98% of all users missed it :nutkick:
A
AlexUnwinder
Those 98% of users never peek into the application release notes, which document each new feature in details (including this one of course):
o Added new “Benchmark” tab allowing you to use hidden RivaTuner Statistics Server’s benchmarking engine, which was previously available to reviewers only. The engine is providing you the following features:
§ You may define a hotkey for beginning framerate statistics recording. Once the recording begun, it stays active for all subsequently started 3D applications, even after rebooting the system
§ While recording is active you may enable showing own statistics in RivaTuner Statistics Server to see minimum, average and maximum framerate in the On-Screen Display
§ While recording is active you may press “Begin recording” hotkey one more time to restart the recording and reset the statistics
§ While recording is active you may press “End recording” hotkey once to end recording and save benchmark results to a text file, but keep the results shown in On-Screen Display. You may press the hotkey one more time to hide the results from the On-Screen Display
§ Statistics saved to a benchmark results file includes per-application total benchmarking time, total rendered frames number, global average, instantaneous minimum and instantaneous maximum framerates. Benchmark statistics file can be optionally either overwritten or appended on each recording session
§ Per-frame frametime statistics is being pushed to a named pipe so reviewers can use their own client software to collect and display it in realtime while any benchmark is running without system slowdown, which is typical for traditional per-frame frametime logging approach
So you may either stay in those 98% and claim that it is "awful unintuitive couple of programs" or simply start reading documentation. That's really, really helpful skill. :)
