- Jun 1, 2011
- 4,937 (0.97/day)
- in a van down by the river
Processor | faster at instructions than yours |
Motherboard | more nurturing than yours |
Cooling | frostier than yours |
Memory | superior scheduling & haphazardly entry than yours |
Video Card(s) | better rasterization than yours |
Storage | more ample than yours |
Display(s) | increased pixels than yours |
Case | fancier than yours |
Audio Device(s) | further audible than yours |
Power Supply | additional amps x volts than yours |
Mouse | without as much gnawing as yours |
Keyboard | less clicky than yours |
VR HMD | not as odd looking as yours |
Software | extra mushier than yours |
Benchmark Scores | up yours |
So needing a new case for the wife's PC I went with the Phanteks P400A black (she's going from a larger Corsair Obsidian 400R) which allowed me to swap out the front panel on my P400S and do some temp testing. I posted my results from the Phanteks P400S test already. So using the exact same hardware and just switching out the front panels I ran the following tests;
Stress test used - 20 minutes of Intel XTU and took the "Avg" temp at the 15 minute mark in each stress test. PC was then shut off for 15 minutes to cool off before the next test. I used both Intel XTU and HWmonitor (for max temps only) to confirm CPU temps. Ran each test twice to confirm temps.
Case - Phanteks P400 with "S" (silence) front panel and "A" (metal mesh) front panel
CPU - Intel i7-9700k @ 4.9ghz all cores
Cooler - Noctua U12A with both fans set to normal setting in the BIOS (about 1600rpm tops)
Front Fans - two TB silence 140mm @ 750rpm roughly 66m3/h set to full speed setting via BIOS
Top fan rear - Noctua NF-P14r redux set to 950 rpm roughly 90m3/h via BIOS
Rear fan - Noctua NF-S12A @ 1200rpm roughly 105m3/h set to full speed setting via BIOS
GPU - Gigabyte GTX 1660 Ti Factory OC 6G
My basement office temp was 69F (2F cooler then the original P400S tests), all other temps below are in Celsius
P400S Panel test
CPU High Temp after 20 minutes of the stress test - 73c
CPU Avg Temp at the 15 minute mark of the stress test - 66c
P400A Panel Test
CPU High Temp after 20 minutes of the stress test - 70c
CPU Avg Temp at the 15 minute mark of the stress test - 63c
On to gaming;
Played the DLC of the Witcher 3 the past week and while I didn't run any specific test set ups I did keep an eye on the temps and noticed the following after several play sessions with each panel. With the P400S panel my high for both CPU and GPU temps would be around 72-73c with temps generally staying at the 45-55c range on the CPU. GPU temps would hang closer to the high temps.
With the P400A panel my high for both CPU and GPU temps would be around 67-68c with temps generally staying at the 40-50c range on the CPU. GPU temps would hang closer to the high temps.
My personal thoughts on the P400S panel; it's as unrestricted of a front panel as I have ever seen. The holes and their spacing are almost dust filter like and you can clearly see into the case once the case LED lights are on. My fansrun silent (I'm a noise freak) but deliver plenty of outside air to both the CPU and GPU. That said the panel is easy to push in with your finger (will easily bounce back by itself) but I would not recommend it for a LAN PC as I can see the panel getting dented in travel.
P400S Panel test
P400A Panel Test
On to gaming;
