HP PC post issue
65 (0.08/day)
Dear forum members,
I have a weird post issue with an HP 800 G2 tower PC computer. More specifically the PC suffers from intermittent posting, that is while it powers on it does not always post an image. I have tried various remedies, including updating the BIOS to the latest version, switching RAM sticks and trying different RAM slots, removing the graphics card, etc. The issue remains and I am at loss. What is even more strange is that when it does post, the system runs without issue. At this point, the culprit might be the power supply but since it comes with proprietary connections, I cannot change it for another.
Thoughts?
Thanks
ppanickk
13,955 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Well, you can change but you would need to ensure it too is proprietary and compatible. Since EVERYTHING inside the computer depends on good, clean, stable power, and since these are failing PSU symptoms, you may need to, at least have that PSU tested by a qualified technician if you don't want to gamble and just buy a compatible replacement supply and hope that fixes the problem.
65 (0.08/day)
Thanks.
2,351 (0.43/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
13,955 (2.04/day)
Nebraska, USA
Mouse Logitech M190
I was hoping it would have been something else, other than the PSU
It could be something else, but as I noted above, everything inside the case depends on good, clean stable power. So it is important to ensure you are providing that before replacing anything else.
177 (0.28/day)
France
System Name the thing / the second shit / boxshit pc
Processor r5 7500f / fx 8350 / w3680 @ 4.2GHz
Motherboard b650 LiveMixer / 990x evo r2 / x58 sabertooth
Cooling assassin x 120 se / stock crap w/ 92mm fan / NH-U12P SE2
Memory 32gb @6400mt.s cl32 / 16gb / 24gb cl11
Video Card(s) 6700 xt / w2100 / hd 5870
Storage 7.25 tb on 9 drives / 1tb on 2 drives / 2tb on 4 drives
Case centurion 5 II / focus g / silencio 550
Audio Device(s) DT 990 Pro 250 ohm, scarlett 2i2 3rd gen
Power Supply straight power 11 750w / random no-name 500w / cooler master gx 550w
Mouse g502
Keyboard corsair something
Benchmark Scores slower than your phone
Could also be the mother board.
Last one that failed on me had about the same symptoms.
4,113 (2.61/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
You can get an adapter, such as:
and then use a normal non-proprietary PSU.
The PSU must also physically fit in the HP tower case, which is not a given.
65 (0.08/day)
It could be the motherboard too, in which case, the system belongs to the bin.
After further testing, I noticed something different with my PC's boot behavior. At first, I thought it either booted or didn't about half the time when I pressed the power button, but that’s not exactly right. What actually happens is that about half the time the PC boots quickly and loads Windows without any issues. The other half, it boots with a delay of a few minutes after I press the power button. It gets stuck on the HP splash screen for a few minutes, then eventually loads Windows and runs normally. I find this really confusing and can't figure out why. Has anyone experienced something like this before?
