_________________________________________________________________________________________________________
CONCLUSION
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 2:03:22 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-POEENK8
OS version: Windows 10 , 10.0, version 1809, build: 17763 (x64)
Hardware: MS-7B51, Micro-Star International Co., Ltd., MPG Z390 GAMING PLUS (MS-7B51)
CPU: GenuineIntel Intel(R) Core(TM) i5-9600K CPU @ 3.70GHz
Logical processors: 6
Processor groups: 1
RAM: 16338 MB total
CPU SPEED
Reported CPU speed: 3696 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 1353,90
Average measured interrupt to process latency (µs): 2,003557
Highest measured interrupt to DPC latency (µs): 1352,80
Average measured interrupt to DPC latency (µs): 0,850530
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 145,793831
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0,000840
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0,000844
ISR count (execution time <250 µs): 22393
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 126,282468
Driver with highest DPC routine execution time: storport.sys - Microsoft Storage Port Driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0,000524
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 451.67 , NVIDIA Corporation
Total time spent in DPCs (%) 0,002367
DPC count (execution time <250 µs): 602014
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 0
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: svchost.exe
Total number of hard pagefaults 1355
Hard pagefault count of hardest hit process: 532
Number of processes hit: 22
PER CPU DATA
CPU 0 Interrupt cycle time (s): 11,587752
CPU 0 ISR highest execution time (µs): 145,793831
CPU 0 ISR total execution time (s): 0,374870
CPU 0 ISR count: 22393
CPU 0 DPC highest execution time (µs): 115,931818
CPU 0 DPC total execution time (s): 0,640355
CPU 0 DPC count: 407683
CPU 1 Interrupt cycle time (s): 1,974450
CPU 1 ISR highest execution time (µs): 0,0
CPU 1 ISR total execution time (s): 0,0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 94,218074
CPU 1 DPC total execution time (s): 0,121058
CPU 1 DPC count: 32820
CPU 2 Interrupt cycle time (s): 1,750553
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR total execution time (s): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 126,282468
CPU 2 DPC total execution time (s): 0,024594
CPU 2 DPC count: 14770
CPU 3 Interrupt cycle time (s): 1,745632
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 94,737013
CPU 3 DPC total execution time (s): 0,203063
CPU 3 DPC count: 119207
CPU 4 Interrupt cycle time (s): 1,849094
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 26,488095
CPU 4 DPC total execution time (s): 0,042732
CPU 4 DPC count: 18578
CPU 5 Interrupt cycle time (s): 1,877149
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 13,774351
CPU 5 DPC total execution time (s): 0,019303
CPU 5 DPC count: 8956
